Author Topic: Macpro fans  (Read 899 times)
Offline cowasakiTopic starter
Macpro fans
« on: June 04, 2021, 01:17:47 pm »
Probably asking the reverse question to most but I have a dead Mac Pro and there a four nice fans in there. I have extracted them but cannot get them to turn. There is a four pin header with ground, VCC, OP and VM
Sticking 12v and ground into the fan does nothing but there are then two additional pins. Allegedly 2.5-5v to be me of these changes the speed but I can’t get anything to happen with any of the four fans.
Any ideas?
Offline tooki
Re: Macpro fans
« Reply #1 on: June 05, 2021, 10:25:23 pm »
Say what now?
Re: Macpro fans
« Reply #2 on: June 05, 2021, 11:11:48 pm »
Say what now?
I typed this on the phone which has a tendency to mess around with spelling or whole words!
Allegedly 2.5-5v on another pin changes the speed but I can’t get anything to happen with any of the four fans.
Offline Nominal Animal
Re: Macpro fans
« Reply #3 on: June 05, 2021, 11:42:51 pm »
According to this, the pinout is GND, 12V (VCC), tachometer output (O/P), and Motor Voltage (VM).
VCC is used for the tachometer logic, not to power the motor.  The motor is actually controlled by a 2V - 12V voltage on the VM pin – this is MUCH wider range than the typical ~ 7V to 12V on 3-pin PC fans.  Apparently, for "normal" speeds, VM is about 5V, which, again, is very low for typical voltage-controlled 12V fans.  The motor current is drawn on the VM pin (the ones on Mac Pro 5.1, up to 750mA).
So, I suggest you try connecting VM to +5V, and GND to ground (these are the two outermost pins), and you should get them spinning at a "typical" speed.
(I would not be surprised to find out they're not rated to run at +12V continuously.)
