Author Topic: Magic Smoke Release  (Read 863 times)
Offline andersjm
Magic Smoke Release
« on: September 02, 2017, 09:32:37 am »
Hi forum,
Thought I'd share some pictures I took of the circuit board in a fluorescent light fixture that stopped working in our house. We got a new one under warranty, but since I was curious why the old one stopped working, I disassembled it.
I can't really see which component blew. could it be the transformer?
High res images:
http://andersmusikka.se/burn/whole_product.jpg
http://andersmusikka.se/burn/whole-burn.jpg
http://andersmusikka.se/burn/burn-detail1.jpg
http://andersmusikka.se/burn/burn-detail2.jpg
Offline andersjm
Re: Magic Smoke Release
« Reply #1 on: September 02, 2017, 09:45:00 am »
Looking at it a bit more, it seems like the thin L-shaped trace close to the mains input has blown.
Could they have been using a thin trace as a sort of cheap fuse?
I checked out the diode bridge, it seems to work. The transformer-like-thing (which I think is actually some kind of input filter) also seems okay.
Well, I'm not going to attempt any repair, just curious why it failed.
Offline Ian.M
« Reply #2 on: September 02, 2017, 11:31:22 am »
Either something has gone dead short on the output side of the bridge (or the input filter cap shorted), blowing the 'fuse' track, or the 'fuse' track blew on a switch-on surge.  The plasma then triggered an arc across between L and N, which probably tripped your breaker.
Check the filter cap and the chopper transistor.  If neither are shorted, repair could be as simple as cleaning the board and fitting a single strand of tinned copper wire of an appropriate diameter to replace the fuse track.  See http://www.gxk.org.uk/info/wire.htm.  If the chopper transistor is shorted, its probably BER, as they often take out the control chip when they blow.
« Last Edit: September 02, 2017, 11:32:54 am by Ian.M »
