Author Topic: Magnetizing my ESD-safe screwdrivers?  (Read 1095 times)
Offline NicholsMattTopic starter
    • www.mattnichols.io
« on: March 08, 2022, 09:19:43 pm »
Hi all,
I got a nice set of the Wera ESD-safe screwdrivers a little while back and while working with them a common gripe of mine is that they are not magnetized.
Would there be any big reason not to magnetize these specific screwdrivers? I'm not doing anything particularly delicate and I have other magnetized screwdrivers in my lab but it would be nice if these were also magnetized. Just wanted to check with the hivemind to see if there were any reasons I was overlooking.
Thanks!
« Last Edit: March 08, 2022, 09:37:27 pm by NicholsMatt »
Offline Gyro
Re: Magnetizing my ESD-safe screwdrivers?
« Reply #1 on: March 08, 2022, 10:01:51 pm »
You can always demagnetise them again.
Best Regards, Chris
The following users thanked this post: NicholsMatt
« Reply #2 on: March 09, 2022, 12:51:06 am »
Fair enough. Thanks!
« Reply #3 on: March 09, 2022, 08:09:45 am »
The cheap magnetising and demagnetising unit you buy will work with those.
Offline jpanhalt
« Reply #4 on: March 09, 2022, 10:40:01 am »
I just stick a small, cylindrical rare earth magnet to the screwdrive about 1 to 3 cm above the tip.  Works great for holding tiny screws, and once removed, there may be some residual magnetism, which is easily removed if needed.
« Reply #5 on: March 11, 2022, 02:17:03 am »
Thanks guys. I have one of the screwdriver magnetizers/demagnetizers so I'll just use that on it!
