Author Topic: main motor wiring  (Read 3829 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
main motor wiring
« on: February 23, 2011, 12:51:18 pm »
I've been shown a motor by someone at work as he can't figure out how to connect it up.
I has four terminals: A1, A2, L1, L2. A2 and L" are connected together. He also has the wires from a capacitorand does not know where to put them.
Offline Sionyn
Re: main motor wiring
« Reply #1 on: February 23, 2011, 01:04:36 pm »
it been ages since ive buggered with motors 3 years ago at collage
what is to be wired to dol, star delta ?
eecs guy
Offline Psi
« Reply #2 on: February 23, 2011, 01:14:50 pm »
Does it also have a centrifugally operated switch?
« Last Edit: February 23, 2011, 01:17:34 pm by Psi »
Offline tecman
« Reply #3 on: February 23, 2011, 02:45:32 pm »
Unfortunately most motor wiring and lead designations are manufacturer specific.  Try looking online on the manufacturers site and see if there is any information.  Motors can be multi-voltage, reversible, two speed, etc.  many combinations exist.
Paul
Offline PetrosA
« Reply #4 on: February 24, 2011, 05:32:49 am »
I has four terminals: A1, A2, L1, L2. A2 and L" are connected together. He also has the wires from a capacitor and does not know where to put them.
More info is needed but it sounds like a cap start split-phase motor. If it is in fact a split-phase motor, one of the two windings is the start and the other is the run. If it's single phase, Line would probably go to A1 and one lead of the cap, the second lead of the cap would go to L2, and Neutral would go to A2+L1. Is there any nameplate info available like voltage, motor type, manufacturer etc?
I miss my home I miss my porch, porch
  • Global Moderator
« Reply #5 on: February 24, 2011, 06:32:28 am »
I'll have a look at it today and get all the information I can off it
Offline Jimmy
« Reply #6 on: February 24, 2011, 12:56:58 pm »
+1
I have wired up single phase pumps like this.
However it could be either
Permanent-split capacitor motor or a Capacitor-start induction motor
Live to A1   A2 to Cap    Cap to Neutral "or Starting switch then to Neutral"
Live to L1    L2 to Neutral
The capacitor changes the phase angle relationship between current and voltage this causes the motor to only spin in the correct direction.
Is that all the terminals on the motor or are they just the ones you dont know how to connect
Offline Zero999
  • 0999
« Reply #7 on: February 24, 2011, 10:56:00 pm »
How large is the motor?
If it's under 1kW or so and doesn't require a high starting torque, it's possible it's a permanent capacitor run motor in which case the capacitor is always connected in series with one of the windings.
