Author Topic: Making PCBs on glass  (Read 5235 times)
Offline bradleytronTopic starter
« on: June 20, 2012, 07:11:17 pm »
I found this very interesting instructional DIY video for making PCBs on glass for anyone who might be interested.
Re: Making PCBs on glass
« Reply #1 on: June 20, 2012, 07:56:14 pm »
Sharp made a glass substrate and put a complete working Z80 processor on it, just to show off their amorphous silicon on glass technology
Offline krenzo
« Reply #2 on: June 20, 2012, 10:23:13 pm »
I am personally offended by that man's soldering iron tip.
Offline T4P
  • Country: sg
    • T4P
« Reply #3 on: June 21, 2012, 12:44:24 am »
It's like he never ever took care of it !
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #4 on: June 21, 2012, 01:29:58 am »
You should see mine!
Offline ChrisW
« Reply #5 on: June 21, 2012, 08:28:31 am »
Why would you want to make PCBs on glass for?
Offline TriodeTiger
« Reply #6 on: June 21, 2012, 09:22:17 am »
Isn't it clear?
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline WorldPowerLabs
« Reply #7 on: June 21, 2012, 09:15:15 pm »
Isn't it clear?
"Crystal" clear!
« Reply #8 on: June 22, 2012, 02:55:19 am »
As with the project shown in the video, a touch sensing application for one example. I'd also like to know if leakage currents on fiberglass material would be the same or better with glass, e.g., for high voltage circuitry.
« Reply #9 on: June 22, 2012, 04:59:27 am »
Glass is better, after all most high voltage insulators are made from it.
Though that depends on whatever glass you use, some are quite conductive.
Offline tesla500
« Reply #10 on: June 22, 2012, 08:08:05 pm »
Isn't it clear?
I see what you did there (quite clearly).
Offline siliconmix
  • Country: wales
« Reply #11 on: June 22, 2012, 08:27:55 pm »
dont see the point of using glass .not very flexible hard to drill and dangerous .
Offline T4P
  • Country: sg
    • T4P
« Reply #12 on: June 23, 2012, 08:26:58 am »
Glass shards ... OUCH
« Reply #13 on: June 23, 2012, 09:34:09 am »
Easy to drill glass, just use tungsten carbide bits and lubricant. Of course the range of drill sizes is limited, I have only seen 6mm and 10mm glass bits, they work very nicely.
