Author Topic: Soldering Tutorial Hoax from April Fools Day  (Read 4363 times)
Online Homer J SimpsonTopic starter
« on: April 28, 2014, 01:47:30 pm »
Online GreyWoolfe
  • NW0LF
Re: Soldering Tutorial Hoax from April Fools Day
« Reply #1 on: April 28, 2014, 03:43:32 pm »
I laughed through the whole video.  The sad thing is that someone without 2 numbers of an IQ to rub together to get a spark of intelligence will see this video and offer to fix a friend's computer using the techniques outlined within.  Of course, both parties will be amazed that the repair didn't work and the factory smoke came out. :-DD :-DD :-DD
Offline electronics man
« Reply #2 on: April 28, 2014, 04:01:35 pm »
he is so good at soldering, so profresional and just great. Dave should take in spiration from this mans great work, the method of rremoving that QFP chip so good and left no harm to the board what so ever, so amazing :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD
follow me on twitter @get_your_byte
Offline MacAttak
« Reply #3 on: April 28, 2014, 04:27:25 pm »
In reality, for many simple repairs where you are just re-capping a board that isn't too dense with components - wouldn't the "technique" of just yanking the electrolytic caps off with pliers work fine? They are a pain in the ass to remove intact, causing lots of extra board heating as you try to reflow both leads at the same time while pulling the cap. It seems that there would be far less stress on the board by physically yanking the cap off and then quickly desoldering each lead individually. I mean - the caps are bad and being replaced anyways.
I get it that he was going for comedic effect.
Offline miguelvp
« Reply #4 on: April 28, 2014, 05:47:56 pm »
If you don't mind replacing the board too. You'll lift the pads by using such "technique".
Offline tom66
« Reply #5 on: April 28, 2014, 07:52:12 pm »
The blowtorch.  :-DD That was... impressive.
« Reply #6 on: April 28, 2014, 08:00:49 pm »
I use that to remove components, though the board will typically not survive at all.
Offline lapm
« Reply #7 on: April 28, 2014, 08:16:05 pm »
Nice video.  :-DD What surprise me is i have actually seen this sort of fix attempts on various stuff... And then they were suprised they cant return the kit under warranty anymore...
How ever i seem to have same grey soldering station with blue backlight lcd screen... Works ok for my need..
« Last Edit: April 28, 2014, 08:19:23 pm by lapm »
Electronics, Linux, Programming, Science... im interested all of it...
Offline Jay_Diddy_B
« Reply #8 on: April 28, 2014, 08:27:36 pm »
Hi group,
For IC removal, the gas powered blow torch can damage to board. I like to use a chain saw to carefully cut through the leads.  ;D Since I am concerned about carbon monoxide poisoning I have switch to a battery powered saw:
http://en.stihl.ca/STIHL-Products/Chain-saws-and-pole-pruners/01583/Lithium-ion-chain-saws.aspx
I also find that a 'weed-wacker' is a very effective way of de-capping a board. The FS-90R is great if you have a lot capacitors to change:
http://en.stihl.ca/STIHL-Products/Grass-trimmers-brushcutters-and-clearing-saws/Powerful-brushcutters/21129-211/FS-90-R.aspx
Jay_Diddy_B
Offline kolonelkadat
  • Obviously, windows are central to Windows.
    • Force Project X
« Reply #9 on: April 29, 2014, 07:22:58 am »
lol that was awesome, but it made me wonder...
Whats wrong with using isopropyl to clean a board?
Offline Shock
« Reply #10 on: April 30, 2014, 01:41:05 pm »
Nothing, unless your board is already clean and your making little tin snowmen.
