The energy which is extracted from slowing down the wind.
Yes that is a perfectly fine explanation for when vehicle is below wind speed. But how you do that when you are above wind speed and apparent wind speed changes direction?
In the blackbird type craft the propeller blows the car forward in the same direction as the wind. In that case the propeller blows against the wind slowing it. Even when the car is traveling down wind faster than the wind, the exhaust from the prop leaves the prop faster than the wind recedes and so is slower (relative to the ground) than the wind.
The gearing between the prop and the wheels provides the power to turn the prop. The wind is pushing against the prop wash and the combination of forces between the prop and the wheels provides the energy, i.e. the power to make this work. The fact that the wheels move with the full velocity of the vehicle while the wind speed is a part and the prop wash is the other part means the wheels get power from the force of the wind and the prop, but only have to power the prop. Net power input is from the wind.
Just noticed your signature so I will assume you may be owning an EV.
Imagine your EV has an empty battery (completely empty) and you have a strong wind from the back of the vehicle and you are on a perfectly flat road.
Now the wind will push your vehicle and your vehicle max speed while pushed by the wind can not exceed wind speed. (I hope you will agree with that).
But now you can use your regenerative brake to start charging battery while your vehicle wind speed will be way lower than wind speed since now there is a lot of resistance as you take wind energy and store it in to the battery and at some point you decide you got enough maybe 1% SOC and even with that you can exceed wind speed for a few minutes.
That is exactly how blackbird works other than propulsion is delivered by a propeller fan (instead of the more efficient wheel) and the energy is not stored in a lithium battery but in the air as pressure differential so as you charge you also start using some of the energy.
And to make it even more clear say your Tesla has a flat rear end with a total surface area of 2m^2 (not aerodynamic at all so CoD of 1).
We will also make the assumption that vehicle drive train is perfectly efficient no friction or even rolling resistance.
Also let say wind speed is a constant 25m/s = 90km/h = 55.9mph
Then direct down wind Tesla will have this amount of wind power available 0.5 * 1.2kg/m^3 * 2m^2 * (25m/s-vehicle speed)^3
If vehicle speed is zero (friction brakes ON then there is of course no wind power available to charge the battery).
Then as soon as you remove the friction brakes wind power will be available.
Say vehicle barely moves at 2m/s then if you want to maintain this low speed all you need to do is charge the battery at this rate
0.5 * 1.2 * 2 * (25-2)^3 =
14.6kW (it may be just half of this in a real vehicle as there is a wind gradient due to interaction with road and vehicle has quite a bit of friction loss).
If you where to drive at 10m/s while you where charging then less wind power will be available 0.5* 1.2 * 2 * (25-10)^3 =
4.05kWAnd at 20m/s vehicle speed it is only 0.5* 1.2 *2 * (25-20)^3 =
150WYou can see where this is going.
There is no wind power available to a direct down wind vehicle even if it is ideal case no friction loss and if there is no energy storage device then it is not possible to exceed wind speed.
