Hi I am Back..
I was racking my brains how to explain how this is Possible .
First clear your minds and think of a Bumblebee .. Ok you say this is off topic . well not really.
According to all known laws of aviation, there is no way that a bee should be able to fly. Its wings are too small to get its fat little body off the ground. The bee, of course, flies anyway. Because bees don't care what humans think is impossible.
Yes you ..
That this machine can go faster than the tail wind for only very short time . because .
The wind first pushes it upto the tail wind speed .
Now comes the tricky part . First the wind MUST NOT CHANGE SPEED at the point of acceleration . HARD as wind is variable .
The propeller pitch is changed to the right angle ( those who missed that part in the video watch again) .
now at this moment there is no longer wind pushing from the back . Only from the front . when travelling at the same wind speed .
an air pocket is forming at the front of the machine . Which is at a LOWER air pressure vacuum bubble . That is rotating round the front in a
kind of whirlpool the centre is now acting like a vacuum suction . The air resistance will drop so there is a state where there is no longer any
front air drag slowing it down . The Propeller still has air flow & ground power . but the friction lose is smaller .
This is when their Red marker flag moved backwards .
This is the point it enters the Air vortex tunnel . and starts to get sucked as well as the tip velocity of the propeller is at its highest .
and is Now Blowing . Houston we have Go for acceleration .
This will only last while the tail wind remains constant maybe minute or 2 or just seconds .
When the tail wind speed changes the front air pocked is broken .
The point is it is possible maybe only for short times maybe a few minutes on a good day.
World records have been beaten in micro seconds . So I reckon a minute is a
The point with the bumble-bee is a good one.
However the rest of the explaination is way to complicated and leads to wrong conclusions.
To understand the effect, better just irgnore electrodacus - too many false claims on his side and making things more complicated than they are.
There was an adjustment of the prop, but this was just to optimize the vehicle. Onece a working setting of the prop is found, the backbrid should work fine and reach a speed faster than wind with a constant setting, starting from a low speed or stand still. There was no change in prop during the runs on the treadmill.
Some fine adjustment may help to find the highest speed - for the given wind speed.
The whole effect can be understood in steady state (so all speeds are constand). Thus no need for energy storage.
The wheels dirve the prop and the prop drives the vehicle relative to the air.
The question that remains is if (and under which conditions) the wheels can generate enough power from the given thrust (force) of the propeller to power the propeller. With more power available from the wheels the vehicle can go faster than the wind, with less power it can not - at least not in this way. From the theoretical side this is simple, even though the result may be confusing to some and some may not be able to understand.
It may look like it could violate the conservation of ernergy, but it is not.
We consider the case moving at the speed of the wind:
The prop sees effectively zero air speed.
The power needed by the prop to generate a fixed amount of thrust is independent of the wind speed.
The power the generator can produce is force ( thrust from the prop) times vehicle speed relative to the ground.
The speed relative to the ground is wind-speed.
There is a constant power required and an available power proportional to the wind speed.
So with enough wind speed the wheels can provide more power than needed to drive the prop. The excess power can be used to more the vehicle faster, that is faster than the wind.
The technical realization still need a good prop and low friction to keep the power lossed. So it needs a well trimmed system, with the prop not trying to go to fast.
