Tally me on the skeptic side.
The sail analogy doesn’t hold water, pardon the pun. The sailboat sail is not traveling along the same vector as the wind. The propellor on this contraption is. At ground speed equivalent to wind velocity, there is no longer any wind force being applied to the propellor airfoil, unlike a tacking boat sail. Envision a ball traveling down an incline. Its speed relative to the surface of the incline is faster than its velocity vector towards the ground, and in the absence of friction, its acceleration across the surface of the incline would exceed the acceleration of gravity. Simple vector analysis. Doesn’t apply to this vehicle if it is aligned with the wind.
Carefully edited video showing the wind string indicating forward airspeed could result under a number of different, TEMPORARY scenarios. I never saw a view from directly in front of the vehicle to confirm perfect alignment with the wind.
Not only do I not believe this vehicle’s speed can exceed the wind speed when aligned downwind, I don’t believe it can equal the wind speed due to frictional losses. Believers will have to explain to me what source of energy can accelerate this vehicle above the wind speed once the speed is equivalent, at which point every molecule of air surrounding and in contact with it has 0 relative velocity, and overcoming frictional losses at the same time!
Set this up with anemometers along the path to confirm the constant wind velocity, evidence of perfect alignment with the wind, a long enough course to eliminate the possible effects of wind gusts, and an unedited, continuous video, and you’ll have my attention. Until then, to me this myth is busted.
Jeff
