How would that be violated by a sail dissipating all or most of the wind energy and only transferring a small portion of that energy to the vehicle?
The formula used earlier that seems to be widely accepted as correct (the drag equation) is also exponential and doesn't diverge to infinity as the vehicle speed approaches zero. In fact, it doesn't matter whether the vehicle is stationary or moving beyond how that changes the relative speed of the wind and vehicle.
So now you are positing some new drag or sail formula that would give you an extremely high pressure and thus an extremely high initial acceleration for a 10m/s wind and a stationary vehicle. So what would the pressure and acceleration be if you had an 11m/s wind and a vehicle moving at 1m/s? Would that be different?
What experimental tests are you referring to?
QuoteThat energy storage device will be charged during the initial acceleration phase
Where is the acceleration phase on the treadmill?
I think I explained that before here but it is when you put the vehicle on the treadmill.
When you put the vehicle on the treadmill and hold it in place, this is equivalent to the vehicle traveling downwind exactly at windspeed [ (wind speed - vehicle speed) = 0 in your equation ] So according to you, there's no energy to be stored -- and you're right, at least about that. But when you let go, the vehicle instantly rolls forward, faster than the wind.
There is maybe a second or two when you touch the vehicle to treadmill until all energy storage devices are fully charged up that means all wheels get to same speed as the treadmill the propeller gets to nominal speed and the pressure differential is created.
For that small treadmill model we are talking about 0.25 to maybe 1Ws (1J) of total stored energy.
The kinetic energy needed for that vehicle to accelerate from zero (when you release) up to 1m/s (never got that fast in the video) is 0.5 * 0.5kg * 1m/s^2 = 0.25Ws (0.25J) basically nothing is needed to be stored in pressure differential to be able to accelerate that small vehicle to 1m/s even to 2m/s will not take much and vehicle was only demonstrated for way lower speed. The treadmill is just to short to show the vehicle accelerating to whatever max speed it is designed for and then show also how it will slow down (that will take again as much as to get there).
What stored energy is there when the vehicle is stationary? You claim that there is zero available energy when the relative windspeed is zero, so there's nothing to store. By your thinking, all the storage occurs when the vehicle is traveling slower than windspeed.
So, how long would we need to hold that vehicle stationary for all that "stored energy" to dissipate? And why do we care about max speed? Isn't any speed beyond wind speed proof that it works?
Your model, and your understanding, is flawed.
What do you mean by stationary vehicle ? Vehicle before it touches the treadmill ? if yes then of course there is no stored energy.
No. By "stationary" I mean the vehicle is being held stationary on the treadmill. The wheels are in contact with the treadmill, turning, and the propeller is spinning. The vehicle speed and the windspeed are equal. This is exactly equivalent to a vehicle traveling directly downwind at the speed of the wind. And no matter how long you hold the vehicle stationary, when released the vehicle will accelerate.
You claim there is no available energy when the vehicle is stationary, since "windspeed - vehicle speed = 0". Even if we ignore your equation, and at windspeed there is stored energy in a pressure differential (which I dispute -- I claim there is no stored energy adequate for even a brief burst of acceleration), how long do you think this stored energy will persist before dispersing into the surrounding environment?
There is measurable stored kinetic energy in the spinning propeller, and rotating wheels, and the mass of the vehicle itself, but unless you have some sort of gearshift or prop-feathering (which the treadmill vehicle does not) none of these will cause the vehicle to accelerate, they will only slow the rate of friction-caused deceleration. And yet, the vehicle accelerates.
Also my point is that no vehicle can exceed wind speed directly downwind unless it has an energy storage device.
I'm very confident that online calculator that I liked is accurate in describing pressure on either a wall or a sail directly downwind.
The crazy explanation that vehicle when above wind speed directly down wind will take power from the wheel to supply the propeller is exactly like saying a motor and generator connected together with a belt are a free energy generator.
That is because when you take energy from the wheel that is directly taken out of the vehicle kinetic energy Ws or Joules and since propeller is maybe at best 70% efficient can only put back 70% of that back in to kinetic energy and so vehicle will have lower speed.
What you can see if you take a video from the side is the decrease acceleration rate
and that will not correspond to Derke's or anyone else's prediction.
In short, energy is extracted from a 20km/h input and is applied to an output working against a 0 km/h reference.
And that is wrong and there is no sense in repeating this all over !.
Very confident is has to be seen with a grain of salt: The calculator is for a different problem: the force a wall has to withstand, when close to an edge (kind of clif if you want). The Zones are not the place where the pressure in the air is measured, but the distance of the wall from the edge. Close to the edge there is some concentration of the wind - so the real value to compare is the one far away from the edge.
The calculated force is not that impressive to support the claimed high power from a sail.
So I am glad you are confident in a calculator that contradicts your claims.
Better have more confidence in the calculator for the bicycle power that showed that it is possible to drive with relatively low power against an head wind.
@electrodacus
A Bumblebee can't fly .!!
Same as electrodacus can't believe a simple
Solution. That if everyone says the 🌎 is round .
He would argue its flat because my spirit level says so ..
So if everyone here has proven it does work .
Plus there has been a video showing it works
. There for Bumblebee can fly also faster the tail wind .
Your ideas of what is true and false , was is, and what can .
Maybe beyond your comprehension .
It wouldn't matter if Albert Einstein could tell you that your wrong .
You are living in some sort of self denial.
Get over it and except that it can and does work.
No, it's not. Your motor and generator are operating at the same speed - but the the two sides of the Blackbird mechanism are not.
Yes, there will be a reduced efficiency in the power extracted from the wheels through to the propeller - but the propeller is pushing against the wind. With the blackbird travelling at wind speed, the wind will appear as a stationary wall of air - and THIS is what the propeller is pushing against. <== IMPORTANT POINT!
Warning: The following uses terms like power and energy in a conversational style - NOT an engineering one! Change the words as you see fit - but follow the intent.
- Let's say wind speed is 20 km/h
- Power is extracted from the wheels which are rotating at a tangential speed of 20km/h
- This power is transferred through a gearbox to rotate a propeller. (The ratio of the gearing is important here - which includes propeller characteristics.)
- The propeller then pushes against a wall of air that appears to be stationary ( 0 km/h ) from the perspective of the vehicle.
The extracted energy will cause a drop in speed, but the additional thrust will cause an increase. Finding the equilibrium point is the trick. Is is below wind speed? Is it above? Is it equal to wind speed?
Clearly shows you do not understand power and energy. 20km/h ~ 5.5m/s
If you take 5.5W form the wheel (1N * 5.5m/s) and put all that in to propeller (ideal case) the most propeller can output is 5.5W thus no acceleration possible even in ideal case.
The gear ratio is irrelevant since you can still not output more power than you input.
This is exactly what others including Derek will try to say it is so silly I do not even know what to say. Luckily there are people that understand all this they just seems to be unwilling to waste time with you (all).
If you think with a 5.5W input the propeller can output more then I have a free energy generator for sale.
The gear ratio is very relevant, as it determines how much thrust / force the propeller will produce. With a good gear ratio propeller can create more than 1 N of thrust from the given 5.5 W. This is possible as the prop sees essentially standing air. 1 N at zero relative speed is zero ouput power from the prop.
What is a "free" energy generator good for that can create 0 W when the wind is blowing. There is quite some energy taken from the wind.
When you take 5.5W say for 1 second then that 5.5Ws (5.5J) energy will be subtracted from the vehicle kinetic energy and since kinetic energy is proportional to speed speed will also be reduced.
Now all you have is this 5.5Ws (5.5J) and no matter what gear ratio you have you can not deliver more than the same 5.5J to the vehicle kinetic energy assuming ideal case.
So yes you can have a gearbox with say 2:1 ratio so input is 5.5m/s 1N and output can be 2.75m/s at 2N it will still only put back 5.5Ws (5.5J) in the vehicle kinetic energy since gear box is not magic and can not output higher power than it has available at the input.
So you just get confused as you do not use the correct speeds in your equations like Derek subtracting wind speed from vehicle speed (ridiculous).
The gear box does not increase the power, but the prop or wheels on the treadmill work relative to a different speed. Because of the lower speed the gear box can reduce the speed so much to generate more than 1 N ( e.g. 2 N). With 2 N of force to drive the vehicle forward and 1 N of force to work against it, there would be still 1 N going forward and thus an increase in speed. It is the force that decides which way the vehicle moves, not the power.
The gain in power is from slowing down the wind with those 2 N. 2 N pushing against the 5.5 m/s wind is a power source of 11 W and thus plenty of power. It is not free energy, but energy taken from the wind.
You will never (I mean never) get 11W with an input of 5.5W. Thinking like this is that resulted in this wild explanations.
Sure you will, and the Blackbird does just that. There's no big mystery how, either. You simply don't understand the energy conservation laws that you continually cite.
The only way you get that 11W on the output is if you add another power supply in parallel or series with the first one.
Yes, that's the principle. The propeller and the wind are 'in series', so to speak. If you like bad analogies, you can compare the various 'speed' of the players with voltage. If the wind and the vehicle are at the same speed you can compare that to a power source and a sink--say a charger and battery--that are both at the same voltage so that no power flows. But if you add an isolated DC-DC converter across the source and then put its output in series between the source and sink, now power will flow.
So the wheel-to-propeller link can be considered as a sort of boost converter that allows power to go from an original source that is the same or even lower voltage than the sink.
