Author Topic: mesure speed  (Read 880 times)
Offline zbida
mesure speed
« on: May 17, 2017, 02:34:13 pm »
hi everyone, am working on a project and I want to measure the speed motor pin, so I should count the number of the pulse on a period, so I make a test project and I send the data to us but I still have 0x00 value any suggest please
Offline rstofer
Re: mesure speed
« Reply #1 on: May 17, 2017, 02:57:51 pm »
The probably belongs in the Beginner Forum...
How about posting your circuit?  In fact, the entire project...  How are you counting the pulses?  Are you using a uC or a frequency counter?
Online jeroen79
Re: mesure speed
« Reply #2 on: May 18, 2017, 01:29:35 am »
What troubleshooting/debugging steps have you taken so far?
Have you verified the sensors output? And the input of your counter? And any steps in between?
If using a microcontroller add a debugging routine to indicate if the sensor's output is received.
