I am looking for how others go about doing front panel lettering on metal cases . I have got to do one ,and want an easy way.
Years ago I remember doing it with those rub on letter's and number transfers ,then spraying over them with a clear laquer to protect .The last one I did was in the late 90's when I used a printer to print on some kind of clear transparency that I got ,then it was stuck to the front of the panel (that one has turned yellowish over the years for some reason.)
I wonder if a toner transfer method might work ,laser print then transfer to the metal panel with an hot iron then protect. Do you think it would last though. ?
How do some of you guys do it.?
