Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Meter frequency measurement module
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Meter frequency measurement module (Read 1906 times)
electronium
Newbie
Country:
on:
December 20, 2023, 06:15:45 am »
Hello guys, I hope you are doing well
Is it possible to measure city electricity frequency and pwm peak of power transistor with this module? How is it possible?
Logged
TizianoHV
Regular Contributor
Country:
Re: Meter frequency measurement module
Reply #1 on:
December 20, 2023, 11:11:44 am »
this "DIY Digital LED Frequency Counter 1Hz-50MHz USB 5V Crystal Oscillator Meter Tester Kit" is not able to measure directly mains voltage (max 5V). You'll need a step down transformer and probably a voltage divider.
If you search online you can find cheap 220V-12Vac lamps transformers and add a voltage divider to step down 12VAC to around 1.5VAC (2.2k / 220R). Or you can use one ZMPT101B module (
https://it.aliexpress.com/item/32810872584.html?spm=a2g0o.productlist.main.1.235d72f1KsgXg1&algo_pvid=5cedd623-1aa3-43be-aafb-4a6810c65149&algo_exp_id=5cedd623-1aa3-43be-aafb-4a6810c65149-0&pdp_npi=4%40dis%21EUR%211.29%211.29%21%21%211.38%21%21%402103853f17030696575861289e8150%2110000000419948036%21sea%21IT%213408016261%21&curPageLogUid=pECiFK0w13YZ
) and regulate it to the correct voltage. Before connecting to mains put everything in a box to avoid touching mains.
What do you mean with "pwm peak of power transistor"?
Logged
https://tiziano-bielli-ee.github.io/
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
