I am considering all my future projects that need less than 5V @ 500ma (2.5W) to be powered only by USB micro B connectors, even if there is absolutely no USB functionality.
I find these connectors are becoming ubiquitous, and there are plenty of 5V phone chargers with captive cables ending in a USB micro B, or even 5V chargers with just a full size USB A receptacle. The the user would use a USB A plug to micro B plug cable. Also, that same cable can be used with a PC or laptop to power my appliance (provided it consumed less than 500mA)
If my appliance needed more than 500 mA, then it could potentially hardwire the signals like a mobile phone does to say it needs more (ala. the USB charging spec)
finally, again in the case of needing more than 500mA, I can always use a USB wall wart / plug pack that can supply 1A or 2A, etc... what ever I needed. The caution I see here is that if my appliance consumed more than 500mA and was plugged into a standard USB port that was only able to supply 500mA, it might blow fuses on the port and make the consumer angry at my device. I think this situation is real, and would have to be protected against, somehow, definitely like the phones do it.
This discussion could go the way of the previous forum discussion regarding Dave's uSupply and his thoughts on using USB to power the supply. I am strictly saying that if my device needs less than 5V @ 500mA (2.5W) then I would like to use a micro USB B receptacle to power it. If I needed more than that, I would have to think carefully about using USB without also including the ability to negotiate power (ala the charging spec)
I just see that the bulky barrel connector is not really needed anymore, and the part is about 3 times the price of a usb micro B connector.
So any thoughts ? Is this a good or bad practice, a misuse of the connector, or any other reasons not to do this in the manner I've outlined it??
thanks!
