Do you need a high current powersupply?
Buy a high current opamp for $20 (eg 3A OPA548 or $30 for 8A OPA549) and attach it to a CPU heatsink+fan
-Wire the 3 batteries in series to the opamp supply rail.
-Stick a pot on the opamp input to set the output volts
-Stick a pot on the opamp current control input to provide an adjustable current limit
And wow, you now have a 1.2 - 35V 3A/8A adjustable linear powersupply with adjustable current limit. It can even sink current!
Ok, so it has some disadvantages, but its really easy to build. There's even a example diagram in the datasheet.
You just need the $20 opamp, two pots, and few bypass caps plus maybe a large electrolytic on the input and the gain resistors, that's it!
(well, maybe a 7805 to get 5V for the input logic)
But yeah, its pretty minimal parts wise.
The opamp even has overtemp protection.
Hint: if you don't need 36V lower the number of batteries in series.
There will be less heat/wasted energy.
