Author Topic: Microscopic high speed Vinyl Record Playback video...  (Read 891 times)
Online BrianHG
« on: January 06, 2018, 07:06:20 am »
Coooool...  This is what it looks like....  :popcorn:  Enjoy...
__________
BrianHG.
Offline helius
Re: Microscopic high speed Vinyl Record Playback video...
« Reply #1 on: January 06, 2018, 07:08:55 am »
See also
Offline Ampera
    • Ampera's Forums
« Reply #2 on: January 06, 2018, 07:10:00 am »
Everything's better in slow motion.
Professional complainer-in-chief criticizing other people's code
Programmer and bumbling Unix fool
Op @ EEVBlog IRC: irc.austnet.irc #eevblog
Online TerraHertz
    • It's not really a Blog
« Reply #3 on: January 08, 2018, 03:18:20 am »
Arrgh! This is what it looks like when you don't clean off dust first, and deliberately force the needle to skip tracks, scoring cut lines between tracks over and over again.
Could someone who doesn't hate vinyl records redo this please?
Offline Ampera
    • Ampera's Forums
« Reply #4 on: January 08, 2018, 03:44:40 am »
I've never figured out why people who enjoy vinyl records get so defensive about other people's stuff.
Nobody who uses compact cassettes, CDs, 8-track cartridges, or the like that I know of gets upset at people for abusing their own things.
Offline helius
« Reply #5 on: January 08, 2018, 04:54:52 am »
There are far more valuable phonograms than the other media types you listed, and correctly playing phonograms always requires more work and care than the other types.
The high-speed footage is marred by a very strange aluminum-foil setup which may be responsible for much of the dust. I actually find it very helpful to be able to see the damage caused by skipping the needle as a way of showing why you shouldn't allow that to happen.
The following users thanked this post: BrianHG
Online BrianHG
« Reply #6 on: January 08, 2018, 06:41:39 am »
After looking again, yes, skipping the needle, you can see the actual physical damage to the vinyl.  I can understand the lighting difficulty while trying to maintain the temperature of everything.  Looking at the difficulties involved in high speed filming this actual playback, I can forgive the dust, not to mention that that dust would be pretty much invisible at normal viewing size.
At the second set of skipping, played back at 1/4 speed, you can clearly see the needle carve out 2 thin shaving streaks of vinyl and leave the dent over the middle bump.
« Last Edit: January 08, 2018, 06:48:04 am by BrianHG »
__________
BrianHG.
