I call BS. In my experience, as soon as people know that something emits microwave RADIATION, they start running scared. Case in point: we completed installation of a new radar antenna under a dome on a tower. Dome is visible for several miles around. Due to long lead time on waveguide, we couldn't hook up the transmitter to the antenna for several weeks. Sure enough, in that time, we got at least two complaints from people living nearby that their WiFi stopped working and that their satellite TV stopped working.
For a while after I started working at my current job, I could swear I 'heard the radar PRF' while eating lunch, about 100 meters away from an S-band antenna with a 1 MW transmitter attached. It turned out one of the techs had a police scanner set up at his desk, with the squelch turned on. When the radar scanned across the building, enough signal broke through the squelch that I could hear it down the hall. Felt quite silly when I found out.
Years later, in the same lunch room, I thought I heard weird high pitched sounds that were very difficult to localize. After much effort and help from a colleague, we tracked the noise to a Wifi router. It was a dried out cap in a switch mode supply that caused the coils to vibrate. Swapped out the cap and the noise went away.
Yes yes, anecdotes are not evidence, but I'm willing to bet there's a more benign explanation for all this.
