Hello guys, I have seen a lot of people on the net swapping the s6 battery with the S7-S7E battery, wich has a lot of mAh.
I was thinking to do the same with mine, and other friends of mine are interested to perform this mod
Now, I am pretty sure that changing a battery, with another, having the same voltage (same number of cells), more less same capacity (500mAh) will not give me any problems, and they are of the same size S7-S6 (S7E is slighly more thick)
This could be a big improvement for a phone like that, bacause the only con that I have found in it (in 2.5 years) is the capacity of the battery
This mod can save my money, because buying a mew phone, just for the battery (because I use it only for work) is a waste of money
What you think about that guys?
