Author Topic: Low profile DDR3 DIMM. Compatible with normal DIMMs?  (Read 3813 times)
Offline wilfredTopic starter
« on: January 04, 2014, 09:59:25 am »
« Last Edit: August 21, 2018, 08:54:28 am by wilfred »
Offline Fsck
  • sleep deprived
Re: Low profile DDR3 DIMM. Compatible with normal DIMMs?
« Reply #1 on: January 04, 2014, 10:07:38 am »
they're identical to normal dimms, just physically shorter
"This is a one line proof...if we start sufficiently far to the left."
Offline Jon86
« Reply #2 on: January 04, 2014, 10:32:53 am »
Yep, exactly the same. I expect they just want you to spend lots more on regular size ones, that or they're just very stupid, which is possible too.
Death, taxes and diode losses.
Offline Stonent
« Reply #3 on: January 04, 2014, 09:01:39 pm »
In some cases I've seen the smaller dimms using higher density chips that some motherboards don't like. I haven't seen it recently but I have seen it before.
Offline hiddensoul
  • I hack with the battery in..
    • The ham Shack
« Reply #4 on: January 05, 2014, 10:52:38 am »
I was in a shop today that had 2GB DDR3 DIMMS for $2.50 (clearance, just 2x). They looked lower in height than the ones I have and when I asked about it the shop told me they were for SFF (small form factor) PC's and wouldn't work in a normal MB that has standard sized DIMMS.  I am inclined to doubt it but since I don't actually have any experience with SFF PC's I wasn't sure.
 Can someone confirm for me either way please?
At that price buy a couple and if they don't work turn them in to keyrings
Mark "Pockets" Clohesy
http://hamshack.org
VK3PKT
Offline Jon86
« Reply #5 on: January 05, 2014, 11:59:57 am »
Nice! Does it have the optional USB?
Offline Jon86
« Reply #6 on: January 05, 2014, 12:24:35 pm »
No, only parallel. Thought I might use it with a Z80 SBC I am planning to build. I had the guts of a POS printer back in the early 80's I used on a Z80 board I had back then. It was only 32 column video so it was ideal for listings. And it was the only way I could do graphics.
I've always wanted to use one of these in my projects, instead of having the usual 16x2 LCD, just print all the data off with one of these!
