Author Topic: LTE CAT-M1 supported by all 4G providers?  (Read 970 times)
Offline TantalumTopic starter
« on: December 20, 2018, 04:19:47 pm »
Hello
I needed a 4G LTE modem that I wanted to use with a NanoPi Neo.
Since I only need it for sending/receiving SMS and check emails, I don't need a LTE module with high speed connectivity.
(I know a GSM/GPRS module @ 8$ would be fine, but they have a too high consumption and RF emission)
There are some not too expensive modules on ebay that use a SIM7000E modem.
http://simcomm2m.com/En/module/detail.aspx?id=168
It is compatible with GSM/GPRS and LTE CAT-M1(eMTC) and NB-IoT.
Now, my questions.
Is the LTE CAT-M1 supported by all 4G providers (Europe) or does it need a specific implementation/equipment by the providers?
Do I need a specific M2M subscription???
Thanks
« Last Edit: December 20, 2018, 10:46:01 pm by Tantalum »
Offline ChristopherN
    • app22 UG (haftungsbeschränkt)
Re: LTE CAT-M1 supported by all 4G providers?
« Reply #1 on: December 20, 2018, 06:47:22 pm »
Hi Tantalum,
NB-IoT and M1 networks are currently in testing phases around Europe. Certain cities will have coverage, but you will need a special contract to use any of those networks. Those contracts are only given to industry customers in most cases and require a lot of paperwork as well as minimum orders in the 100s to 1000s SIMs. You could try your luck and contact M2M / B2B sales of your local provider and ask for a free card or an evaluation pack.
Full rollout across will take time. Please also note that the current roaming contracts don't include M1 and NB-IoT as of now, so you won't be able to use the card in any other than your home network.
BR
Christopher
« Reply #2 on: December 20, 2018, 07:24:14 pm »
Thank you for your answer!  :)
« Reply #3 on: December 20, 2018, 08:26:24 pm »
And PTCRB in the States. Luckily there is no such thing in Europe.
