I've just done an emergency repair of a ceiling, in what could best be described as a porch, using 12mm outdoor ply. Now they need to paint it. All the stuff I've found online assumes that the ply is going to be exposed to the elements (ie it is a floor or wall), and thus suggests a lot of priming and sealing.
As this is a ceiling it will only be exposed to humidity, so I don't think they need to go to such lengths.
Is there a paint (white) that will cover the grain of the plywood with a few coats?
Erm, erm, I used a cordless screwdriver during the job, is that sufficient to legitimise such a post on an electronics forum?
