Author Topic: MLC3700A N5FBUN (msc-logic ARM) any info  (Read 540 times)
Offline fableTopic starter
  • Country: cs
« on: February 12, 2023, 10:27:41 pm »
Hi, i have device with damaged MLC3700A "N5FBUN" . I found mlc3700a"N5FH1M"  but i dnt know if there is a  difference?
Online ataradov
    • Personal site
Re: MLC3700A N5FBUN (msc-logic ARM) any info
« Reply #1 on: February 12, 2023, 10:44:18 pm »
This is likely a manufacturing lot code and does not matter to the functionality. But if it is a programmable device, then you would need a way to get the firmware and a programmer. There seems to be no obvious documentation.
Alex
Offline amyk
« Reply #2 on: February 13, 2023, 02:22:55 pm »
That's just lot/date code.
Looking at the very minimal information I could find, it doesn't appear to need programming:
http://www.mcslogic.com/sub2_DigitalAudio_MLC3700.htm
