Author Topic: 74LVC1G vs: 2G ??  (Read 1433 times)
Offline GreggDTopic starter
74LVC1G vs: 2G ??
« on: July 17, 2018, 02:27:56 pm »
I am missing something simple.
What is the difference between a SN74LVC1G74DCUR and SN74LVC2G74DCUR ?
I thought 1G was one gate and 2G was two but it is not.
Re: 74LVC1G vs: 2G ??
« Reply #1 on: July 17, 2018, 03:46:51 pm »
Not the answer and
I need the xxx74 as it has RESET (CLR*)
« Last Edit: July 17, 2018, 03:50:42 pm by GreggD »
Offline Benta
« Reply #2 on: July 17, 2018, 04:33:50 pm »
Your understanding the 1G is one function and 2G is two functions is correct. It seems TI messed up with the nomenclature at some point. The 2G datasheet is from 1999, where the 1Q datasheet is from 2009.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3 on: July 19, 2018, 05:38:28 pm »
Comparing both datasheets, it seems the 2G variant was a bit more thoroughly characterized over the operating temperature range of -40 to +125°C. although they did not push it to 200MHz at this range (the 1G is shown results at that frequency and temp range).
Overall, the parts are functionally identical.
