If you want the BS kept a minimum, probably look at asrock, if you want none at all, look at supermicro,
The part i find the funniest is that a 4 layer PCB can be a marketing feature on some of the modern motherboards.
When your running tens to hundreds of various GHz or faster trancievers across 30cm of board area, being able to get away with 4 layers speaks wonders to how tolerant the trancievers and standards are.
