Author Topic: Mouser sent me the wrong part  (Read 7427 times)
Offline juliom
  • Country: mx
« on: August 27, 2016, 12:59:59 am »
Hi guys, I am new to this forum.  :)
I need some help. I just bought some parts from MOUSER but I think they sent me a wrong part.  :--
I ordered the TPN8R903, TSON package, but they sent me some 4560, SOIC package.
Do you have any idea what is that 4560? (maybe an OpAmp) It doesn't seem to have any logo.  :-//
This is very disappointing, I can't imagine how many SMD capacitors or inductors (no markings to identify the parts) they send wrong  :palm:
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: Mouser sent me the wrong part
« Reply #1 on: August 27, 2016, 01:13:45 am »
I looked at the device datasheet and it really looks like it is the wrong device - the markings stated there are very different.
Offline Voodoo 6
« Reply #2 on: August 27, 2016, 01:33:03 am »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 27, 2016, 05:05:08 am »
Ya. Happens from time to time.  Just order it again.
Since it's just one I suppose there's no point in sending it back.  Just tell 'em it was a mistake and they'll probably send the right part for free, too.
Seven Transistor Labs, LLC
Offline JPortici
« Reply #4 on: August 27, 2016, 07:59:28 am »
none.
not yet at least.
though sometimes error happens. somebody must have bulk ordered all 0805 resistors he could find. two different cheapo's went out of stock while they were processing my order so i couldn't see it. they apologized instantly and will send the stuff for free as soon as it becomes available
have you even considered contacting them? they have very excellent customer support.
Offline hans
« Reply #5 on: August 27, 2016, 08:01:54 am »
Just call them up and have them send you the correct parts.
For small parts like this, I can't imagine they want you to send it back.
I've had wrong parts sent to me by RS and Farnell before, and all were very compliant in getting the right goods to me. I'm sure Mouser will have the same level of standards.
Offline matseng
    • My Github
« Reply #6 on: August 27, 2016, 08:18:41 am »
Some 25 years ago I got lucky and received a nice Weller soldering station instead of some small cheap parts like a bag of caps or so.  Having spent thousands upon thousands of dollars from the company I didn't feel too bad about keeping it. ;-)
I'm still using it today as a secondary iron with a larger tip inserted. But the plastic in the handle have started to crack after all these years, so maybe it's time to retire the poor thing.
Offline Voodoo 6
« Reply #7 on: August 27, 2016, 08:47:10 am »
Edited.
« Last Edit: August 28, 2016, 05:06:19 am by Voodoo 6 »
Offline Psi
« Reply #8 on: August 27, 2016, 09:50:01 am »
Ya wouldn't feel to annoyed if they sent you a reel of these by mistake  :-DD
Although. I'm not sure a reel of those actually exists anywhere on earth.
Perhaps it could be needed for some military stuff maybe.
http://www.digikey.com/product-detail/en/xilinx-inc/XCVU440-2FLGA2892E/XCVU440-2FLGA2892E-ND/6132314
« Last Edit: August 27, 2016, 09:52:11 am by Psi »
Offline MT
  • Country: cn
« Reply #9 on: August 27, 2016, 11:44:32 am »
4560 is used in in truck load of analog mixing desks so its not a bad device as such!
Online MasterTech
« Reply #10 on: August 27, 2016, 02:37:17 pm »
you didnt post a pic of the label outside the bag...
Online Ian.M
« Reply #11 on: August 27, 2016, 03:31:26 pm »
The fun starts when the foulup is in your supplier's goods inward process rather than their order picking process.
We tried to order 5 off of a particular semiconductor (probably a line output transistor but I don't remember the details) and got five bags of ten right angle PCB mount dual phono connectors, labelled with the stock code of the transistor!   By the time we'd dragged our rep into it and they got it semi-sorted out, they'd sent us another two batches of phono connectors, and we'd sourced the correct part elsewhere, so our distributer's rep cancelled the order item they'd spent the last month trying to fulfill unsuccessfully.   He didn't want the phono connectors back either (presumably because they were fairly low value and they'd have had to rebag them all) so we ended up with a draw full.
Online MasterTech
« Reply #12 on: August 27, 2016, 04:30:51 pm »
fixing these mishaps belongs to what is called "reverse logistics" and in few companies does this area work well
Online blueskull
  • Country: cn
  • BA7LKP
« Reply #13 on: August 27, 2016, 04:37:06 pm »
I've been a long time Mouser user, and it have never failed me. I would say I can understand if they screw up maybe 1 per 1000 orders.
If I put anyone in that position, can you promise you will manage 1M types of parts, each 1k pcs, without having any labeling problems?
Offline juliom
  • Country: mx
« Reply #14 on: August 31, 2016, 07:35:33 pm »
I just contacted them and they sent me the part for free  :-+ I am just waiting for it to arrive.
I remember reading some sort of Mouser advertising about "you receive exactly the quantity you need" I thought they used some sort of automated robotic system with triple checking before sending packages out, but they don't  :-\
I am going to keep buying from them but now I am going to check every package to be sure of what I receive
I bought some time ago an Amazon Kindle, the product went missing  :-// They said it was just one in millions of packages.
If a killer just kill one in five billion people, why does he go to jail?  :horse:
Offline wraper
  • Country: lv
« Reply #15 on: August 31, 2016, 07:41:44 pm »
And they kept their promise, sent the right quantity, different part though  :).
Offline station240
« Reply #16 on: August 31, 2016, 11:01:14 pm »
Why wonder, they made a video of their warehouse.
Offline LabSpokane
« Reply #17 on: August 31, 2016, 11:19:15 pm »
Mouser has sent me the correct parts for free even when the mistake was *100% mine*.
Offline matseng
    • My Github
« Reply #18 on: September 01, 2016, 08:45:18 am »
That sounds very good to me.... I order just 10 pcs but I really need 45 of them, so they will send all 45 to me anyways.  That is an absolutely fabulous service :-DD
Offline MT
  • Country: cn
« Reply #19 on: September 01, 2016, 12:49:48 pm »
Farnell sends me parts not even ordered for free! Multiple times! :-+
I collect them in a "special parts" box!
But this is nothing compared what can hapen at the big elephants, i once worked for one of these and we regularly got resistor/cap's e.g 10kohm for the first e.g 3000 units the rest 2000 was 100kohm, sometimes , not often but it hapend now and then, we could get triple different values on the reel! This from the big manufacturers, Murata, Vishay, KOA, AVX, etc, etc. This was very expensive as it needed manual refitting later in the mounting process. :D
« Last Edit: September 01, 2016, 08:16:01 pm by MT »
Online langwadt
« Reply #20 on: September 01, 2016, 01:43:12 pm »
I've heard one guy get by asking how many they had in stock and ordering that plus the number he needed so they'd have to restock
Online Ian.M
« Reply #21 on: September 01, 2016, 02:14:56 pm »
You have to be a bit careful if you do that.  e,g. if we'd done that it could have had two possible outcomes:
* Either our whole stockroom would have been taken up with boxes containing 50000 PCB mount phono connector.
* Or we'd have had to eat a 30% restocking fee on the 4995 transistors we didn't need  which would have had both our accountant and bank manager screaming because these were *NOT* cheap jellybean parts, even with maximum quantity discount and in that sort of quantity, would have put a serious hole in the annual budget.
As our supplier's rep couldn't get it sorted, we knew it was totally FUBARed.  IIRC the next issue of their catalog had the old ordercode discontinued and a new code for that same transistor, as that was what it took to get it unFUBARed!
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #22 on: September 01, 2016, 02:19:21 pm »
If you can afford to pay the maximum price on a part and at the same time be vulnerable to availability issues, this sounds like a great way to order parts.
Have You Been Triggered Today?
