Author Topic: Mouser/Microsoft breaks forum URLs  (Read 2520 times)
Offline apellyTopic starter
  • Probe
« on: November 17, 2013, 07:06:14 pm »
Mouser/Microsoft breaks the forum URLs. Mouse over the URL below and notice the missing pair of equals signs on the end. Can't escape them with = either. XSS prevention error here at EEVblog perhaps?
http://nz.mouser.com/Search/ProductDetail.aspx?qs=LKPZbmhlTxgthWb1p8PC8A==
Didn't bother to look and see if all mouser products end with what looks like a pair of nulls.
Offline IanB
Re: Mouser/Microsoft breaks forum URLs
« Reply #1 on: November 17, 2013, 07:19:26 pm »
Testing a fix:
(Oh wow, that was way too hard. I think the SMF forum code is broken.)
alm
  • Guest
« Reply #2 on: November 17, 2013, 07:21:20 pm »
Try replacing the equal signs by %3d. Most likely just a flaw in the UBB parser.
  • Probe
« Reply #3 on: November 17, 2013, 07:30:08 pm »
Ah yes. %3d does work. Doesn't display well in the post, but does indeed translate correctly in the URL.
Thanks for the workaround.
Offline IanB
« Reply #4 on: November 17, 2013, 07:41:16 pm »
Try the way I showed above:
[url=http://nz.mouser.com/Search/ProductDetail.aspx?qs=LKPZbmhlTxgthWb1p8PC8A%3D%3D]http://nz.mouser.com/Search/ProductDetail.aspx?qs=LKPZbmhlTxgthWb1p8PC8A==[/url]
  • Probe
« Reply #5 on: November 17, 2013, 08:00:06 pm »
Yes, I understand.
I was idly observing (badly) that you have to manually dick with the way the URL is displayed if you want it shown. A bit of a PITA.
I also wonder if it's unique over here. I did google for a minute or two looking for a solution, but nothing obvious came up, so I guessed it was probably a configurable setting. I've never bothered to look at forum software.
