Author Topic: MOV fire risk  (Read 14355 times)
Offline miegapeleTopic starter
  • Country: lt
MOV fire risk
« on: December 10, 2023, 11:21:33 am »
I would like to ask what is general consensus, about MOVS in products and fire risk from them.
I stumbled upon this post there MOV exploded even without triggering fuse, and fuses are quite frequently used with MOVS in surge protection strips, like for example here .
However, it seems MOVs now appear in regular products and even without a thermal fuse. example IKEA here (but not in older generation here ), Samsung 65W here , even cheap Chinese smart plugs have them. However, Apple teardowns I have seen, seems to still omit them.
So, that's the current trends regarding use of MOVs in such devices, is it OK from the fire perspective?
Offline DavidAlfa
Re: MOV fire risk
« Reply #1 on: December 10, 2023, 01:34:25 pm »
Of course Apple sees easy money there, they will just argue it was a mains surge...
Please buy a new expensive thing from us!
Offline jonpaul
Re: MOV fire risk
« Reply #2 on: December 10, 2023, 01:40:05 pm »
Bonjour,
See GE original MOV handbook.
Limited life and fire risk are known.
In 1983 we had a 20 mm GE MOV on a wall plug transient protectopr.
About 20m away a 12 KW cinema lamp had a fault and very high transients were on the 240B mains.
My engineer in the adjacent lab shouts:
"JON!! THERE IS FIRE!"
The MOV exploded and flamed dqwn towars the floor.
The carpet caught fire.
Since that day I havwe never used a MOV.
Jon
Jean-Paul  the Internet Dinosaur
Offline Stray Electron
Re: MOV fire risk
« Reply #3 on: December 10, 2023, 02:33:31 pm »
   I found a heap of very nice and well-made COMMERCIAL quality surge suppressors in some surplus a while back.  They were mounted in steel boxes with a lot more room than necessary and the boxes were then filled with dry sand.  Presumably to absorb any blast from exploding MOVS. I just grabbed one out of the pile and I don't see a PN on any of the MOVs but they're in groups of 5 each and there are 7 groups of them and each MOV is larger in o.d. than an American quarter. There are five large wires (probably #8 gauge) and three small wires (for monitoring) coming out of each one and they appear to have been made for use on a 3 phase Y-connected circuit.
  MOV tend to fail shorted so they all need to be fused IMO and packing them with sand and in a sturdy flame proof enclosure is a GOOD idea. These a bit bit weird in they way that they're fused, each incoming power lead goes through a 1 Ohm 1% resister (probably a fusible resistor) and then has a small 22? gauge bare wire that connects to a tent shaped insulator with 9 other small wires attached and each of the other wires connects to a group of MOVs. So it looks like the 1 Ohm resistors and the small bare wires are intended to serve as fuses.   I picked up about 60 of these of various sizes and we tested a bunch of them and they seems to be designed to operate on 120, 240, 277 and 480 volt circuits and both Delta and Y configurations.
Offline shapirus
  • Country: ua
Re: MOV fire risk
« Reply #4 on: December 10, 2023, 02:43:01 pm »
Shorting the circuit is their actual purpose, is it not?
1) the MOV begins to conduct once voltage across its terminals exceeds a certain value;
2) current flowing through the fuse installed before the MOV increases rapidly and blows the fuse;
3) the MOV is rated for a specific amount of energy that it can absorb before blowing up (which determines its size -- or, rather, its size determines the energy);
4) if the fuse blows before that energy is exceeded, then the circuit designer used proper values and every part has done its job properly. Otherwise, it's bad design.
Am I wrong?
Offline shapirus
  • Country: ua
Offline madires
  • A qualified hobbyist ;)
Re: MOV fire risk
« Reply #7 on: December 10, 2023, 04:28:37 pm »
Or alternatively MOV plus thermal fuse in heat-shrink tubing.
Offline coppice
Re: MOV fire risk
« Reply #8 on: December 10, 2023, 04:34:04 pm »
Those heat shrink sleeves are remarkably good at holding the bits together when a MOV pops. Without that sharp bits can punch through a thin plastic case.
Offline shapirus
  • Country: ua
Re: MOV fire risk
« Reply #9 on: December 10, 2023, 04:42:35 pm »
Considering the thermal resistance between the two, when they are separate parts, and the speed of the process, having them both in the same package (of course still with the heat shrink cover) gives a better chance of them working as expected.
Offline dietert1
  • Country: br
    • CADT Homepage
Re: MOV fire risk
« Reply #10 on: December 10, 2023, 05:18:43 pm »
As far as i remember MOVs also suffer from aging but i can't say whether it is just time or number of surges. Aging tends to increase leakage currents and the thermal fuse is meant to disconnect the circuit when it starts to consume power, heating up to some level. Of course the thermal fuse is far to slow in case of a nearby lightning strike. MOVs also have a significant capacitance, which may help for EMI suppression.
Regards, Dieter
« Last Edit: December 10, 2023, 10:25:38 pm by dietert1 »
Offline nctnico
Re: MOV fire risk
« Reply #11 on: December 10, 2023, 08:38:36 pm »
Agreed. I have seen MOVs being covered by heat shrink tubing in many devices.
Offline coppercone2
Re: MOV fire risk
« Reply #12 on: December 11, 2023, 06:03:47 am »
I seen mov utterly detonate and disappear but they never seemed to cause a fire risk. Maybe its 240v vs 120.
I also have alot of them around, i think they split up surges or something like that. maybe if there was just one little mov in the house it would be worse
« Last Edit: December 11, 2023, 06:07:03 am by coppercone2 »
Offline Siwastaja
Re: MOV fire risk
« Reply #13 on: December 11, 2023, 07:28:07 am »
Am I wrong?
You are correct, just missing one detail. Point 4, fuses "reset" nearly indefinitely as they cool down, hence the energy you refer to in point 3 is an integral which is also assumed to reset: as you explain, if the MOV and fuse are dimensioned together correctly, if the fuse does not blow, then the MOV does not blow up either, both cool down and reset for the next cycle. Fair enough, this is correct.
But MOVs have additional energy limitation, which is non-resetting over the lifetime. Every clamped peak, even benign ones which are not even close to exceeding said repetitive limit (and thus not even close to blowing the fuse), wears out the MOV, until it one day fails short from such small event.
This of course does not change the fact that a correctly dimensioned fuse is needed to protect the MOV from fire, and usually, the components surrounding the MOV also need some protection, at least a physical gap.
The following users thanked this post: 5U4GB
Offline madires
Re: MOV fire risk
« Reply #14 on: December 11, 2023, 10:19:33 am »
The thermal fuses commonly used together with MOVs are fuses (stay open after blown) and not thermal switches.
Offline Kleinstein
Re: MOV fire risk
« Reply #15 on: December 11, 2023, 11:56:13 am »
MOVs get increasing leakage when getting old. So they may slowly run hotter and hotter and thus can overheat without blowing a normal mains fuse. The MOV is usually not flamable (after all it is metal oxide), but the hot PCB and neighboring parts may catch fire.
There are MOVs that aready come with a thermal fuse, e.g. Little fuse TMOV series.
The following users thanked this post: CosteC
Re: MOV fire risk
« Reply #16 on: December 11, 2023, 12:17:24 pm »
I have had one or three Zinc oxide MOV units, NOS GE ones, in the red dipped package, die short circuit while in storage, but in general with 230VAC mains they will all ineviatably fail as short, so best is to make sure they are fused correctly. But as all of those I have used failed safely, small one blowing apart, bigger ones drawing enough current to trip a breaker rather rapidly, often with no apparent damage to the MOV, other than it having a low varying DC resistance, in the order of 10's of ohms, with 1V applied from a multimeter, as opposed to being well over 10M normally. Seen also units with fuses in the path to the MOV units, either as PC board traces, or a proper ceramic fuse soldered into the board, or for the one, with a 20A ATO automotive fuse soldered into a slot in the board. Last one made by Clearline, guess they were happy using a 20A 32VDC rated fuse well past the warranted ratings.
I have plenty in use, often simply mounted in a connection block to an external LED light, to keep the surges down, to keep the lamp life as long as possible, even if the lights are rated for 3kV surge, extra always helps. they still all fail after a while, some soon, some after a year or two, and a few that still work after 4 years.
Online NiHaoMike
    • Facebook Page
Re: MOV fire risk
« Reply #17 on: December 11, 2023, 01:08:02 pm »
It helps to have a large film capacitor, on the order of 5-10uF, in parallel to shunt the small switching transients. That, of course, can only be applied to the L-N or L-L MOVs, using one to ground would cause too much leakage current.
Offline CosteC
Re: MOV fire risk
« Reply #18 on: December 19, 2023, 02:28:23 pm »
Nobody mentioned that while in EU nominal voltage is 230 VAC, the realistic voltages in in many places of network reach 250 V due to photovoltaic and other prosumers trying to sell energy. If MOV is rated for 250 VAC it will leak a lot and age quickly. I am not sure how this phenomenon widespread in USA with its 120 VAC system.
Other aspect is common issue - fuses rated "as high as possible" not "sensible". Lack of inrush current protection forces high fuse ratings, this does not work well when MOV will activate or there is failure of some primary side semiconductor. As usual cheap designs done quickly are not good designs and may caught fire.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: MOV fire risk
« Reply #19 on: December 19, 2023, 02:50:12 pm »
Very rarely, it can be much worse: since the supply is a 240VCT transformer, if the neutral comes loose for some reason (say, improper, faulty, or damaged wiring), more load on one side than the other will shift the neutral voltage, browning out one side and overvolting the other.  UL 1449 for example covers this.
Seven Transistor Labs, LLC
Offline iJoseph2
Re: MOV fire risk
« Reply #20 on: December 19, 2023, 03:39:57 pm »
In the UK fitting MOV's to the mains incoming supply will become more and more common since the regulations have been updated. For example ..
https://hager.com/uk/support/regulations-18th-edition/surge-protection
Quote from: hager.com
18th Edi­tion Re­quire­ments
The 18th edi­tion BS 7671 now stip­u­lates
Pro­tec­tion against tran­si­ent over­voltages shall be provided where the con­se­quences caused by an over­voltage could
(i) res­ult in ser­i­ous in­jury to, or loss of, hu­man life
(ii) failure of a safety service, as defined in Part 2
(iii) significant financial or data loss
For all other cases, protection against transient overvoltages shall be provided unless the owner of the
installation declares it is not required due to any loss or damage being tolerable and they accept the risk of
damage to equipment and any consequential loss.
Offline CosteC
Re: MOV fire risk
« Reply #21 on: December 19, 2023, 05:34:21 pm »
240 VAC is UK peculiarity :) Still, the lost neutral is surely fault condition, unfortunately it may last hours. Good fuse shall disconnect equipment, MOV usually does not survives it, and this is expected behaviour for commercial equipment.
Again, fuse selection is critical, thermally protected MOV will help, but not be enough in case of so long overvoltage - other components will not survive.
Re: MOV fire risk
« Reply #22 on: December 19, 2023, 06:22:28 pm »
In this case, the 240V is not a UK peculiarity; the quoted poster is in the US and was referring to the 240V centre-tapped neutral found in domestic supplies there. AKA split phase, they use both phases where they need more power, ie a tumble dryer, for example.
Offline CosteC
Re: MOV fire risk
« Reply #23 on: December 19, 2023, 07:52:29 pm »
True, yet USA split phase or two phase system is even more peculiar. Still lost neutral at source may generate even more exothermic effects...
You are right. I am forgetting about USA "solutions" mea culpa.
Offline coppercone2
Re: MOV fire risk
« Reply #24 on: December 19, 2023, 08:43:02 pm »
well it seems that I read about more MOV and RIFA explosions from europe. I don't think the US power grid is that bad of an idea. Split phase reserved for crazy devices that belong in the garage.
You pay a bit extra in copper weight but in general the failures are less spectacular.
and I noticed way more brown outs / surges in europe then in the USA. They have less local transformer in europe and there is more line effects that damage devices.
and its nice to be able to service most domestic things with a much less hazardous voltage.
« Last Edit: December 19, 2023, 08:45:26 pm by coppercone2 »
