Author Topic: Looking for banana plugs and terminals at EBAY / Any recomendations?  (Read 2054 times)
Offline 001Topic starter
  • Country: aq
Hi!
I`m need for at least 40 banana plugs (stackable will be ok too) and few banana terminals for my DIY lab
What china source You can recomend? Any ebay sellers etc?
Thanx!
Nothing special! Termal and halvanics effects are not essential.
I`m shoot of money and I`m far from US
The plugs must be cheap and ruged only
« Last Edit: September 16, 2018, 02:15:42 pm by 001 »
Offline coppercone2
Re: Looking for banana plugs and terminals at EBAY / Any recomendations?
« Reply #1 on: September 16, 2018, 02:15:36 pm »
I recommend you buy them from digikey or mouser or try to find deals on well known manufacturers or lots.
the only half decent chinese brand I found was Uni-T. They are kinda decent, but you need to make sure you are not getting the super stiff PVC ones (but at least they did not skimp on conductors for me).
I think my uni-t banana to banana were uni-t brand all silicone, but I on another continent right now from my lab.
Anything else you are liable to get literarly magnetic wire thats like a 1 ohm per meter or more,
The following users thanked this post: 001
  • Country: aq
« Reply #2 on: September 16, 2018, 02:16:49 pm »
Hi!
I`m looking for banana CONNECTORS, not wires  :palm:
Offline coppercone2
« Reply #3 on: September 16, 2018, 02:18:50 pm »
I was actually unsatisifed with my uni-t probes, because they were stiff insulation, but the banana to banana were nimble wire, but the resistance was low with all of them as it should be with probes or test cables.
Offline coppercone2
« Reply #4 on: September 16, 2018, 02:20:35 pm »
you mean chassis mount female?
Or ones to use with your own wire? (so no molded strain relief :X)
Offline Brumby
« Reply #5 on: September 16, 2018, 02:22:39 pm »
I think he means things like this:
  • Country: aq
« Reply #6 on: September 16, 2018, 02:26:45 pm »
What I`m looking for:
OR
OR
AND
  • Country: aq
« Reply #7 on: September 16, 2018, 02:28:05 pm »
any reputable ebay sellers here?
« Reply #8 on: September 16, 2018, 03:42:07 pm »
Frankie Tong, 99centhobbies, though he has sort of gone quiet recently here, moving.
Offline rstofer
« Reply #9 on: September 16, 2018, 03:42:33 pm »
You want to be careful with those banana plugs with the side screw.  You can get a pretty severe shock under the wrong conditions.
I don't make stackable jumpers, I buy them.  Pomona is well represented at DigiKey.
Buy them twice as long and cut in half if you want to attach probes.  It's nice that the plug itself is molded with no exposed metal on the body.
I don't know of any particular eBay sellers.  I did buy a few of these and they seem ok.
https://www.ebay.com/itm/School-Physics-Lab-Multimeter-4mm-Banana-Plug-Probe-Test-Cable-1m-Pair-LW/182341004961
« Last Edit: September 16, 2018, 03:44:50 pm by rstofer »
The following users thanked this post: JugglingElectrons
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: September 16, 2018, 04:08:12 pm »
+1. Check Frankie's store at: https://www.ebay.com/str/99centhobbies
And no, it will not the cheapest around but he did a lot of homework when sourcing these parts.
Offline Bratster
« Reply #11 on: September 16, 2018, 04:49:25 pm »
I'll add another vote for Franky.
Very good quality in my experience.
Sent from my Fi Moto x4 using Tapatalk
