To be clear, the UT61E is a good meter for less than $70 if you can get it at that price. It has some faults, incomplete input protection, fuses not rated for more than 250V on the current range, no back light, no temperature, no auto power off. Its advantages are that it comes with a PC cable (usually RS232) and software, and it has 22000 counts. Don't get me wrong, I like mine but.....
The Amprobe AM270 has much better input protection, has temperature, better fuses, same accuracy, back light, probably same or a little much better build. It does not have a PC cable and software and has 5000 counts. It can be found for well under $90. If you have to pay close to $90 for a UT61E then I would rather see you get the AM270 for its better protection and temperature function.
