Author Topic: my first project :) - need a little help  (Read 12655 times)
Offline SnakeBiteTopic starter
  • Country: il
  • OBSESSED MODDER
« on: July 28, 2011, 06:27:10 pm »
Hello,
After I finished second year at Uni, I decided to start a new project. It's not something new just to improve my project design experience (with you help of course…).
 I want to build adjustable linear power supply 1.2-20v@3A. This PS will have a seven segment display that you can change the voltage and the current (current limit).
The main demand from the PS that it will be as reliable, efficient and stable as possible.
I found the PERFECT voltage regulator - LT3083.
I will use 10,000uf 50v cap as a filtering cap (probably a Rubycon brand(.
I did my homework  and it's seems that I need a 230VAC TO 25VAC @ 3A transformer but i have a few question since i'm newbie :
1. Which transformer should I choose  "Laminated steel cores" transformers or toroid transformer (since i need more efficiency( ?
2. Since the range of the voltage is 1.2 to 20 volts ,  i don't think that the voltage regulator should take all that HEAT (ABOUT 20v*3A = almost 60W!!!) I think i should use a transformer with a multiple taps to minimize the problem. I decided the voltage regulator shouldn't dissipate more than 9w, so I thought to use a few taps that i can connect in series when needed to get the required voltage. here is the diagram of the transformer taps I thought to use:
0v             9v
                 4v
                 4v
                 4v
230v         4v
i thing the easiest way to put my hands on this transformer is wind one myself you have more ideas ?is it hard to wind a transformer?
3. What is the best way to switch the transformers taps? I thought using a relay - what do you think?
And that's it for now
Thanks A LOT for you help ;)
Ido ,Israel
Ido Aricha , Israel.
Online IanB
Re: my first project :) - need a little help
« Reply #1 on: July 28, 2011, 06:37:22 pm »
You can likely find a 12-0-12 V transformer off the shelf that you could use in a 0-12-24 V configuration.
If you don't heat sink the regulator it will limit the output current to avoid overheating. Plan on mounting the regulator on a big effective heatsink if you really want 3 A out of the supply over a range of voltages.
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #2 on: July 28, 2011, 07:30:00 pm »
why not use a SMPS ? at least to drop the voltage from the high to low range. You could put a linear reg after it if you like, you will claw back heaps in efficiency that way
  • Country: il
  • OBSESSED MODDER
« Reply #3 on: July 28, 2011, 07:56:30 pm »
SMPS are don't be that stable as linear PS .
Offline Simon
  • Global Moderator
« Reply #4 on: July 28, 2011, 08:10:47 pm »
well it depends on what you mean by stable. if your talking output noise then yes linear is better which is why you could consider a first SMPS stage to drop the main of the voltage and then a linear reg.
if your talking reliability, well i don't know, I thought SMPS was reliable
  • Country: il
  • OBSESSED MODDER
« Reply #5 on: July 28, 2011, 08:15:55 pm »
simon do you mean to use some kind of PWM for the main voltage drop ? it won't add noise to the voltage?
yes i meant low noise when i said "stable".
Offline Simon
  • Global Moderator
« Reply #6 on: July 28, 2011, 08:18:35 pm »
you can use a 2 stage regulation, say you want 1.2V, you use a SMPS to drop the 20 to 3.5V and then use a linear reg after it to drop to 1.2V, the result is that the SMPS drops the main of the power efficiently and the remainder is done by the linear reg with also cleans up the power and produces low noise.
  • Country: il
  • OBSESSED MODDER
« Reply #7 on: July 28, 2011, 08:21:51 pm »
can you explain more about "2 stage SMPS" ? what stages you mean exactly? i know  a little of  SMPS theory .
Ido
Offline Simon
  • Global Moderator
« Reply #8 on: July 28, 2011, 08:28:52 pm »
use a standard SMPS to drop your transformer voltage and then put a linear regulator after it so that you feed the linear reg say 12v instead of 20V and save o heat dissipation
  • Country: il
  • OBSESSED MODDER
« Reply #9 on: July 28, 2011, 08:47:44 pm »
i don't understand what is "standard SMPS " take computer PS and connect it to mine? how ?
Offline DrGeoff
    • AXT Systems
« Reply #10 on: July 28, 2011, 11:37:23 pm »
If HF noise is an issue, then avoid the SMPS route. You could use a multi-tap transformer and use a range switch to select voltage ranges (or auto tap selection if you are adventurous). Otherwise I'd suggest using several T03 BJT's mounted across an appropriate heatsink to distribute the power dissipation, rather than have it all come from the one device. 60W is easily manageable on a reasonable heatsink, you'll need to do the thermal calcs to choose teh correct device and temperature rise.
Was it really supposed to do that?
Offline Simon
  • Global Moderator
« Reply #11 on: July 29, 2011, 05:58:07 am »
how about we define what the exact requirements are ? as this is a first project the OP may be trying to go over the top causing unnecessary heart ache. Do you really need near "0" noise from the supply ? what will the power supply the realistically used for ?
  • Country: il
  • OBSESSED MODDER
« Reply #12 on: July 29, 2011, 11:15:30 am »
there is no specific use for this PS i just want an stable PS if i build one.
how can i make auto tap selection  ? with a relay?
thanks
Ido
  • Country: il
  • OBSESSED MODDER
« Reply #13 on: July 31, 2011, 11:06:43 am »
i want to buy toroide transformer from china . will it be as reliable as other none Chinese transfomer? i know that transformer are mostly very reliable devices but still...
Ido
Offline Simon
  • Global Moderator
« Reply #14 on: July 31, 2011, 11:55:34 am »
should be ok, a visual inspection should tell if it is really bad, if it is claim your money back
  • Country: il
  • OBSESSED MODDER
« Reply #15 on: July 31, 2011, 02:13:13 pm »
can you tell??
Ido
Offline Simon
  • Global Moderator
« Reply #16 on: July 31, 2011, 03:05:26 pm »
not without handling it and taking it out of the wrapping, no
Offline img
« Reply #17 on: August 02, 2011, 11:09:54 am »
And while you are in the process of power supply design, it might be a good idea to think how you're going to test whether you designed what you think you designed.
For example, since you make an emphasis on stability, what experiment(s) have you got planned to gauge that?
  • Country: il
  • OBSESSED MODDER
« Reply #18 on: August 02, 2011, 04:10:06 pm »
I'm planning to test the ripple with high-end analog scope with no load and under full load and tweak the rails with capacitors accordingly (of course I'll not wait til then to do that i will design it like that that I'll need a little tweeking).
Ido
  • Country: il
  • OBSESSED MODDER
« Reply #19 on: August 03, 2011, 11:49:03 am »
i have a few question about the ADC and the counts of the display.
i want to have good resolution of 5 digit i mean (20.000 volts) so thought i need 4.5 digit ADC but the most significant digit can be only 1 (4.5 digit = 19999) so i have a little problem there . i tried to find 4.75 digit ADC but i couldn't find any .
can you help me out?
Online IanB
« Reply #20 on: August 03, 2011, 03:19:02 pm »
19999 would give a reading of 19.999 V = 20.000 V, which is the resolution you are looking for. Can you clarify the question a bit more?
  • Country: il
  • OBSESSED MODDER
« Reply #21 on: August 03, 2011, 05:10:30 pm »
from what Dave's said in the VBlog on counts i understand (correct me if i wrong) that with 4.5 digit resolution the MSD can only be "1" maximum so it will never can show 20.000 v only 19.999 v.
plus, the 20v i'm limitting the PS is under full load (20V@3A) and under no load it should be more than that like 20.700 or something...
do i understand Dave correctly?
Ido
Online IanB
« Reply #22 on: August 03, 2011, 07:30:52 pm »
For practical purposes a display range of 0 to 19999 counts give a meter range of 0 - 20 V at full resolution. If you want to read above 20 V then you need a display with 39999 counts. But with the 19999 count display you could show a reading of 20.70 V, which might be accurate enough for practical purposes? Also, a properly regulated power supply will be 20.00 V at no load and 20.00 V at full load. If you are expecting the power supply to be unregulated, then I am not sure why you want to indicate the voltage with such precision?
  • Country: il
  • OBSESSED MODDER
« Reply #23 on: August 03, 2011, 08:46:15 pm »
i have a PS and it limited to 40v and when it's not connected to a load it shows 40.7v on screen i thoguht it's normal - guess not...
i want it to be regulate PS but i want it to be more than 19.999v , in case that something happent  , to user will know that the PS is overvoltage...
thanks for clearing it out...
so you say that 4.5 digit ADC will be good enough to show on screen more than 19.999v? what is the maximum limit of 4.5 digit ADC ? what is the maximum voltage that it can show?
thanks
Ido
Online IanB
« Reply #24 on: August 03, 2011, 09:13:30 pm »
I think you are confusing terms here. An ADC is an electronic device or component that converts an analog signal to a binary digital signal. The resolution of an ADC is usually expressed in bits, e.g. 8-bit or 12-bit. (For instance an 8-bit ADC could output values in the range 0-255 counts.) You then have to process this digital value in a computer or microprocessor of some kind.
What I think you are looking for instead is a digital panel meter to read volts. These come in a package so you just connect an appropriate voltage to their input and they display the reading on the display. Many such meters do appear to come in 1999 count ranges, or maybe 19999. This is unfortunate, but if you want to display above 20 V then you will have to find a 3999 count meter or use a 19999 count meter without the 1. (If you ignore the 1 you can pretend it is a 9999 count meter, but you will lose some accuracy.)
