I doubt it's a thermistor.
If it is a satellite part, in space applications, if you want to dump some current somewhere, it will get turned into heat. Problem is you can't use forced air cooling or convection because there isn't any air. Ergo dumping some current into these and leaving it to radiate off instead or conduct or convent is ideal. This is optimised for radiation versus conduction or convection.
