I have a couple of greeting cards, specials with minor electronics, for Halloween 'monster cards', having blinking LED eyes in the special greeting card.
Now, also the unit has a reciprocating mechanism, for producing 'eyeball' wiggles.
The little mechanical box contains 10mm X 3mm motor, and a couple gears. I'm not sure if the little controller IC sends both directions polarity to the motor (IC is inside epoxy dot).
The little gear box is 20mm by 20mm by 8mm thick.
You'd have to check Hallmark Cards, and I will keep a look out, for that special Halloween card.
