Sounds like you need one of these.
http://www.ebay.com/sch/?_nkw=av%20sender&clk_rvr_mfe=search
I have used these with great success in the past.
Regards
Yea that's what I need. If you've used them then I'll take it they work OK.
Thanks.
Years ago I tried a similar video sender, it was a 2.4Ghz model. The experience was really, really bad... It did not work at all for me, and that could have been environment related I guess, but I couldn't get it to work more than 1 room distance away.... beyond that it was fuzz and snow, just like 1976 again
Perhaps a more powerful unit, or a different unit would have worked better, but I didn't experiment with all the different units on the market, and there wasn't very many at that time. Now there seems like more units available, and different frequencies too. I would prefer something lower than 2Ghz, say 900Mhz or 450Mhz but that would need a bigger antenna I guess. For consumer use, the small antennas of the 5GHz models are appealing in your living room.
I just recommend you do your research first before you buy a particular brand, and see if you can find a review of it.
good luck.
