Author Topic: Need advice for adhesives  (Read 1398 times)
Offline LoganTopic starter
« on: December 26, 2020, 04:30:13 pm »
Hello guys.
I need a glue that can bond with glass/crystal and plastic/rubber strongly, but won’t damage the material, and won’t contaminate the lens when volatilize.
Are there any recommendations?
Thanks!
Offline Benta
Re: Need advice for adhesives
« Reply #1 on: December 26, 2020, 06:32:35 pm »
Contact adhesives.
The following users thanked this post: Logan
« Reply #2 on: December 26, 2020, 09:32:51 pm »
UV cure epoxies are about the only ones you will find that will do the glass properly, and will work in a lens.
Offline Benta
« Reply #3 on: December 26, 2020, 09:39:17 pm »
With rubber? Interesting. Do you have some specific hints?
Offline jpanhalt
« Reply #4 on: December 26, 2020, 10:31:24 pm »
Cyanoacrylic adhesives (CA, "superglue")  were developed by Eastman Kodak to attach glass lenses to metals and plastics.  Do not use on plastic lenses or use one of the non-fogging versions.  They adhere quite strongly to rubber.  There are rubberized versions that probably contain neoprene, if you need a flexible joint.
There used to be an ad on TV of a worker being lifted by a 1" square piece of rubber attached to his hard hat.
Offline richnormand
« Reply #5 on: December 26, 2020, 10:50:22 pm »
In my experience do not use superglue stuff on or near optics, particularly in an enclosed instrument.
The vapours can ruin the lens AR coating or give a hazy lens surface. This is doubly true if you have any plastic optical elements in the grouping.
The Kodak glue probably had different properties tailored to their specific application compared to the consumer types.
« Last Edit: December 26, 2020, 10:53:21 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline tooki
« Reply #6 on: December 27, 2020, 01:19:58 am »
I'd suggest contacting an industrial adhesive manufacturer's technical support. (Henkel, 3M, etc)
There are specialty adhesives and primers to bond pretty much any combination of materials. (The magic word in German is "Haftvermittler". For example, there is primer to make superglue stick to Teflon and silicone!)
There are plenty of silicone adhesives that stick well to glass, and won't off-gas anything to haze the glass. I'd be surprised if there isn't some type that also sticks to the type of plastic or rubber you need to bond. You'll just need to know exactly what material it is, since different plastics have radically different adhesion properties, and so do rubbers (latex? synthetic rubber? thermoplastic elastomer? etc etc etc).
Offline pickle9000
« Reply #7 on: December 27, 2020, 02:46:08 am »
uv cure silicone
Offline Doctorandus_P
« Reply #8 on: December 27, 2020, 06:42:23 am »
Different sorts of plastics need different kinds of glue. Some (PE) are not glueable at all, while others (PVC) need specialized glue.
Offline jfiresto
« Reply #9 on: December 27, 2020, 08:18:29 am »
I would also talk with the adhesive makers and get their advice.
I was going to suggest a Modified Silane (MS) polymer adhesive which is low in VOC, but that can be hard to find in the U.S. – or perhaps to identify. The last time I looked for someone, I could find a handful of "advanced" consumer/home improvement adhesives with its characteristics, but their makers/resellers would not say what was in them. It was annoying. Just tell me the chemistry and I will sort things out.
Anyway, if you are not in a rush, I can lay a bead of MS Polymer on a glass slide, wait a couple days, put it under a microscope and check for fogging.
« Last Edit: December 27, 2020, 08:29:28 am by jfiresto »
-John
« Reply #10 on: December 27, 2020, 09:59:15 am »
Thank you everyone!
Offline tooki
« Reply #11 on: December 28, 2020, 12:05:33 pm »
PE is glueable with the right adhesives and primers.
