Author Topic: Need help identifying this vintage IC  (Read 1658 times)
Offline DiddlyJackSquatTopic starter
  • Country: sg
« on: May 23, 2021, 08:02:38 pm »
Found this while I was sorting out my logic ICs and uh, I can't figure out what it is  :-//
[ Specified attachment is not available ]
« Last Edit: May 24, 2021, 05:41:13 am by DiddlyJackSquat »
Offline Benta
Re: Need help identifying this vintage IC
« Reply #1 on: May 23, 2021, 08:25:15 pm »
National Semiconductor. Probably with customized marking.
Offline themadhippy
« Reply #2 on: May 23, 2021, 08:55:00 pm »
maybe an op amp or 2
Offline josh132
  • OSCILLOSCOPE
« Reply #3 on: May 23, 2021, 09:04:24 pm »
Get one of those IC tester thingamabobs. It might tell you what is is.
bu du bu nu
  • Country: sg
« Reply #4 on: May 23, 2021, 10:16:23 pm »
That's what i thought until I tried to google the part number...  :P
natsemi 643 doesn't come up with anything nor does LM3532 make any sense
but here's their old logo
Yup that's right
« Last Edit: May 23, 2021, 10:20:56 pm by DiddlyJackSquat »
Offline Benta
« Reply #5 on: May 23, 2021, 11:04:01 pm »
I repeat: "customized marking".
  • Country: sg
« Reply #6 on: May 23, 2021, 11:48:04 pm »
I should triple check next time, i thought you meant customized natsemi logo  :palm:
Offline amyk
« Reply #7 on: May 24, 2021, 12:22:20 am »
Was there ever an NE3532? Perhaps it's an op-amp?
  • Country: sg
« Reply #8 on: May 24, 2021, 05:31:26 am »
Its definitely from the 80s... a whole lot of chips and transistors was bequeathed unto me and the previous owner used to do audio repair so these could be anything as I have seen strange driver chips like these in the box
https://www.radiomuseum.org/tubes/tube_ay-5-8100.html
Offline amyk
« Reply #9 on: May 24, 2021, 07:21:08 am »
That is not a tube :o
Here's the datasheet for that one: http://www.supermoduul.com/PDF/AY%205%208102.pdf
Offline magic
« Reply #10 on: May 24, 2021, 01:41:36 pm »
It may be from early '70s because the 1977 NS transistor databook already uses their later logo.
Test every pair of pins in diode mode in both directions and see what happens. The pin which has a PN diode to many (not necessarily all) other pins is likely ground.
  • Country: sg
« Reply #11 on: May 24, 2021, 05:53:59 pm »
i do know that's the datasheet but that's how radiomuseum hyperlinks them  ;D
only one pin has a PN diode to another  :scared:
Offline magic
« Reply #12 on: May 25, 2021, 07:55:32 am »
That could be a bandgap shunt reference but I'm not sure if National made anything like that in DIP8 at the time.
Which pins are connected with the diode?
I just tested µA741, NE555, UC3842 and LM358 and sure enough, they all have multiple diodes.
« Last Edit: May 25, 2021, 07:57:24 am by magic »
