Author Topic: Need help in translating Chinese characters at transformer label ...  (Read 1576 times)
Offline BravoVTopic starter
  • +++ ATH1
Need help in translating the Chinese label at the transformer on decoding the wires color, also the text on the left side too, and I assume the number R40W means 40 Watts ?
Attached photos below.
Primary wires are
1. Yellow
2. Red
3. Yellow with green stripe
4. Blue
5. White
Secondary :
1. 2 x White
2. 1 x Green
3. 2 x Blue
4. 2 x Yellow
The 1 Green + 2 Blue wires I assume its the 18V/0.3A dual windings with center tap, CMIIW.
My mains is 220 VAC, and the primary side has 2 X 110V windings, so both need to be connected in series, but what is the correct connection ?
Thanks in advance.
Offline coppice
Re: Need help in translating Chinese characters at transformer label ...
« Reply #1 on: October 30, 2018, 01:10:29 am »
The left column on the label, top to bottom, says:
Red
Yellow
Blue
White
The right column on the label, top to bottom, says:
Blue
Green
Blue
Yellow
Yellow
White
White
R40W is a type number, not a power rating.
« Last Edit: October 30, 2018, 01:13:47 am by coppice »
  • +++ ATH1
« Reply #2 on: October 30, 2018, 01:13:47 am »
Thanks, so the Yellow with Green stripe wire at primary side is the ground/chassis wire ? (As pointed by the red arrow I added to the 1st photo)
Offline coppice
« Reply #3 on: October 30, 2018, 01:16:30 am »
The character pointed at by the red arrow can mean patterned, so I assume it refers to the striped wire.
Offline Nusa
« Reply #4 on: October 30, 2018, 01:26:45 am »
Multimeter should be able to quickly confirm if that wire is attached to the chassis mount.
  • +++ ATH1
« Reply #6 on: October 31, 2018, 03:11:52 am »
Thanks for all helps and aids on this, as I'm on travel, I will report once I sit down with it, and 1st thing to do is to measure the chasis line.
Again, thank you all.  :-+
