Hi, you are right, I couldn't use cyrillic font. As ivan7enych said the EPN is a DC-DC converter which I guess to increase the voltage. What do you mean by electric pusher? It is strange because both ELT and ED have identical symbols. By the way, some of those switches are actually a tilt switch, which is very interesting in design, I've attached it in case you are interested to see. thanks
