Author Topic: New EMC Transient & surge testing lab, Ukrane  (Read 2339 times)
Offline mikeselectricstuff
    • Mike's Electric Stuff
« on: October 04, 2016, 03:47:55 pm »
Day Job: Mostly LEDs
Offline nctnico
Re: New EMC Transient & surge testing lab, Ukrane
« Reply #1 on: October 04, 2016, 04:25:03 pm »
Their mom is going to kick their asses when she gets home!
« Reply #2 on: October 04, 2016, 05:59:03 pm »
I think she is used to that from Kreosan...............
Offline elgonzo
« Reply #3 on: October 04, 2016, 06:01:46 pm »
LOL, if i were living in a house with an interior like that, i would in all likelihood have done the same :P
By the way, i love the poster with the green cat  ;)
« Reply #4 on: October 04, 2016, 06:49:51 pm »
I wonder if that air conditioner still works...
Offline electr_peter
  • Country: lt
« Reply #5 on: October 04, 2016, 08:10:44 pm »
Wow, I always assumed that mains sockets, lights switches, light bulbs and light fixtures were more immune to EMC (or extreme EMC in this case). Everything arced over from high voltage, but damage to lights and light switch is interesting. Is this video real (i.e. not faked)?
Definitely not going to try something like this at my home. Is anyone tempted to investigate effects of HV on lighting circuits in more detail?
EDIT After revieving video I have a hypothesis of what is happening. High voltage, applied from shocker device, initiates arc, which is sustained and increased by mains AC power. All components in lighting circuit arc over, effectively creating short circuit. Arcing explains dark spots on light switch and near the lamps.
And this happened on relatively wimpy mains power in the flat. Try something like this with industrial 400V mains and you will get deadly arc flash. Scary :scared:
« Last Edit: October 04, 2016, 08:18:07 pm by electr_peter »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 04, 2016, 10:42:42 pm »
Thinking some of it is staged, but the idea is plausible.
The mains network is made of wires, moderately well spaced, which therefore exhibit transmission line characteristics.  If anything like good old U.S. "Romex", it'll be on the order of 100-150 ohms.
A spark is extremely fast, mere nanoseconds on the rising edge.  If produced from a capacitor discharge, the peak current can be ridiculous: hundreds of amperes!
At the moment of ignition, the spark delivers a current equal to (HV - Vspark) / Zo.  For a 50kV spark, this could be over 300A.
The wave launches down the wires, bouncing off stubs (such as cords plugged in), and eventually dissipating in the losses of the cable (which is usually PVC insulation, quite lossy at RF) and whatever loads (transformers and light bulbs should be reasonably lossy, if imperfectly matched).
The wire likely has a pretty high breakdown voltage.  Sparks should occur near the first break or opening in the wire, usually where something is attached.
Light fixtures (using something like an Edison, pin or bayonet base) have the terminals relatively close together, so would be prime targets for sparking.  Junction boxes may be as well, if the insulation is pulled tight around a sharp corner, or the wire nuts or screw terminals are rather close together, or near ground.
Appliances will vary.  Most equipment with an EMI filter will shrug off this kind of abuse: there's a big film cap facing the outside world, which will reflect the spark as a short circuit.  Filters which don't have a capacitor in this position, will probably see some sparking around the common mode filter choke.
Sparks to ground may be more dangerous than sparks between the lines.  EMI filters can't afford much capacitance to ground, and often have the CMC facing the line, without Y-caps from line-input to GND.  Thus, a spark will jump across the CMC, since, that's its purpose, it's suppose to allow a large CM voltage drop!
As for energy delivered, I doubt it would be much in a 100/120V environment, but with 240V over there, there is a greater capacity for arc flash, or something like it.  Absolutely, the ionized (spark) path will sink some mains current, especially if it was ignited during a mains voltage peak.
Two industrial applications come to mind:
1. Welding and plasma cutting, where a high voltage starts/assists the low voltage, high current, arc (the HV is usually pulsed HF, generated from a Tesla coil-like circuit).
2. EDM (electro-discharge machining), where the cutting electrode is powered by an aggressive foldback power supply.  The open-circuit voltage is perhaps a few hundred volts.  When a spark is initiated (in this case, on its own, by bringing the cutting tool into near-contact with the work), the voltage drops rapidly, and the current is increased substantially.  Over a longer time scale (~us to ~ms?), tens or hundreds of amperes are dumped into the cut, obliterating the contact area.  (A nimble actuator also withdraws the tool slightly, stretching the spark and preventing continuous arcing, or welding.)  Over time, eventually the whole work surface is formed into the profile of the cutting tool (usually a tungsten or graphite face profile, or a very fine copper wire for making better-than-laser-fine cuts).
Seven Transistor Labs, LLC
Offline ar__systems
« Reply #7 on: July 31, 2018, 09:30:35 am »
Typical equipment has only up to 5K isolation between mains and the rest of the circuit. 50K transients will have no problem destroying anything.
Offline CopperCone
  • *knock knock*
« Reply #8 on: July 31, 2018, 11:18:03 pm »
why would you do this in your house? those people are on crack
