I moved into this new house that has about 10 bed rooms. Its less then 10 years old and as far as I can tell;
It was built with for cable TV RG6
It was later upgraded to a satellite But not sure where the TVs were the wiring has been hacked by Verizon.
It was wired for fios a few years ago. TERRIBLE job everything was just hacked apart and rushed. Instead of connectors there are just holes drilled; with eithernet and cables shoved through them. It looks like there was last two TV's.
So there is one bed room I want the fios TV to travel down the RG6 up to.
How do I tell which cable from the outside goes to the bundle of cables outside the house. Trying to connect a cable box to the room and playing around with cables out side is not really an option because I don't know if the source signal is really working. How would the people that work for the company trace the wires assuming there is nothing hooked up? Almost like I need to do a continuity test with 100's of feet of leads which is not practical.
