General => General Technical Chat => Topic started by: coppercone2 on April 15, 2021, 08:28:32 pm
Title: new Navy pentagon-confirmed UFO videos
Post by: coppercone2 on April 15, 2021, 08:28:32 pm
https://www.youtube.com/watch?v=SKsLK_Na7iw (https://www.youtube.com/watch?v=SKsLK_Na7iw)
tri-copter with a forward thurst? May not be so difficult with modern control systems, the main problems with these experiments in the 1950's were control systems, the designs are very unstable, an simple analog control systems that are small could not handle it. They should be judged on speed, weight and flight time (which determine power plant, how much energy the craft has available) more then anything related to maneuvers, because all sorts of acrobatics are possible with modern microprocessors doing fast cheap calculations to actively stabilize odd geometries. The power plant is the tell tale sign of advanced technology. Could be a drone submarine with drone scout ships.
Title: Re: new Navy pentagon-confirmed UFO videos
Post by: ataradov on April 15, 2021, 09:09:24 pm
Where can we see first hand confirmation from the pentagon? Those people are not fast to confirm any actual observation. Why would they in this case? And the exact wording matters a lot here.
If it is a secret research thing, then why would they present that to congress as UFOs. Presumably congress should know what research is performed  and they can be told exactly what that is.
There is no point in speculating. Without good information, it will just be the same arguments all over again.
And half of the vides here are from thermal cameras, which are not very reliable for random unknown objects. It may have not disappeared into the ocean, but just turned the wrong side to the camera.
Post by: coppercone2 on April 15, 2021, 09:19:06 pm
that looks like night vision (so it goes through a light amplification tube), and I don't know the fox news report says the same thing as the USA today report and its probobly online
the confirmation usually happens when some reporter asks pentagon brass if they can confirm it, I am not going to sit through c-span looking for it
Post by: coppercone2 on April 16, 2021, 01:49:11 am
https://www.youtube.com/watch?v=ZA-h3dIeD_A (https://www.youtube.com/watch?v=ZA-h3dIeD_A)
Maybe the tic tac is some kinda physics particle that interacts with the jet (i.e. the proposed physics objects W.I.M.P. comes to mind, in some kind of form)? Maybe some interacting dust particles by some strange combination of forces? (i.e. odd super alloy turbine grindings that have built up in the atmosphere over the years because of advanced engine technology that behave some how cohesive, room temperature 'condensates' of some kind, the combinations of metals that we make in the conditions that occur in engines are not anything near natural?) Maybe some kind of sphere structure/balloon that forms naturally from the things in the air and is very strong and some how interactive with EM (naturally radar seeking metal frame ultra-solid formed by accumulation/cohesion balloon)? So the plane is kind of acting like force tweezers (laser tweezers, ultrasonic tweezers, etc) based on one of its emissions that lead to the interactive behavior? (just explain wind resistance)
https://www.youtube.com/watch?v=TnW1sESY3JY (https://www.youtube.com/watch?v=TnW1sESY3JY)
Post by: xrunner on April 16, 2021, 02:16:00 am
These UFO videos are mostly all the same - new or old. Some splotch moving on video that reminds viewers of some flying craft. But it's always apparently just far enough away to remain mysterious. When are we going to catch one close enough to see the lights, windows, engines, rivets, or an alien waving to us?
I bet - never.
Post by: David Hess on April 16, 2021, 02:27:29 am
It looked to me like the interference pattern generated by an obstruction in an optical system.  Very bright pinpoint sources can create ghosts obscuring the shape of an object.
https://en.wikipedia.org/wiki/Artifact_(error)
https://en.wikipedia.org/wiki/Lens_flare
Post by: coppercone2 on April 16, 2021, 02:49:05 am
what about the one with the pilot saying he saw a flying propane tank with his eyes
the only lens there might be the cockpit and his eyes, then 3 more guys saying they saw the same thing
did those jets have videcon tubes by any chance? I played with an old tube and the creepiest thing would happen, if it got too dark, the image was visible, but new objects were not visible, so if you stood out infront of it and turn a flashlight on, you teleport into place. I hung it on the roof as a driveway cam for a while before I forgot about it and spiders took over the system, one of them managed to make a web inside the lens some how and I forgot about it
Post by: Ed.Kloonk on April 16, 2021, 03:12:45 am
https://en.wikipedia.org/wiki/It_Came_Out_of_the_Sky (https://en.wikipedia.org/wiki/It_Came_Out_of_the_Sky)
https://www.youtube.com/watch?v=VuPtOtGF4TY (https://www.youtube.com/watch?v=VuPtOtGF4TY)
Post by: AntiProtonBoy on April 16, 2021, 03:54:32 am
You can clearly see there are two identical flare-like artefacts with the same triangular shape on the left and bottom left respectively. I'm betting it's related to the camera aperture.
Post by: coppercone2 on April 16, 2021, 03:59:33 am
you would think the navy, dealing with missiles being launched, which are bright, and guns being fired, and plane afterburners, in all times of day and all weather would know how to deal with and identify camera aberrations, its dangerous because you might think there is a enemy missile and trigger a defense system.. for some reason I don't think its so simple/foolish.. these military systems must be designed to reduce that and the operators trained on how to identify that. and they float on water all the time and constantly scan everything around them, including odd ball dangers like glint from submarine periscopes (reportedly this was one of the best ways to spot a submarine back in the day), possibly frogman goggles, sub surface ships, etc.. they all rely on identifying glint properly.
or enemy gun fire from a ship or an explosion from a ship (be it under attack or malfunction), after 1000+ years of navy service, would probobly make this.. easy to determine? it did not really change importance over the century, they used to light small fires on boats filled with gun powder to act as torpedos.. the camera is new but I figure they must be EXPERTS at dealing with that and all sorts of optical illusions.
The military was fooled before by stuff like this with early warning systems on satellites, but that was 50 years ago, with lessons learned I am sure.
Microwave effecting pixels maybe? but those thermals are usually shielded with germanium that is conductive I think, and the systems must be RF hardened anyway (so you don't mess up a night vision tube with the radar), so they probobly have all the bells and whistles.
Post by: AntiProtonBoy on April 16, 2021, 04:16:27 am
Well yeah, if a craft is actually identifiable, they would not be categorised together with unidentified flying objects, now would they? By nature the objects in question are unidentified because the video quality is bad and you can't infer more details from what's being shown. That's it. There is noting else anyone can say about the object in question. The problem is, people think they can fill in the gaps with a whole bunch of aliens nonsense.
Post by: coppercone2 on April 16, 2021, 04:17:29 am
Well it does not hurt to revisit the case once in a while as we learn more about physics, get more information, etc.
Post by: GlennSprigg on April 18, 2021, 12:28:00 pm
The amazing part, is that I think 'most' of us would 'like' it to be true...  but alas...
ANYONE who has even the slightest Grasp of the enormity of our Galaxy, not to mention the whole 'known' Universe, would have to concur
that no matter how small the chances are for 'life' within other individual star systems, that due to this incredible enormity then 'Life' of some
sort must literally be PROLIFEROUS out there!!!  :phew:   However... that doesn't mean that 'they' have or ever will visit us here on Earth.   :-\
I for one would love it to be so!, but it always gets me why such Beings, (attempting to be secretive), would have lots of glowing/flashing lights!!   :)
Post by: Ed.Kloonk on April 18, 2021, 12:30:49 pm
https://en.wikipedia.org/wiki/Fermi_paradox
Post by: hexreader on April 18, 2021, 12:34:26 pm
Come on guys/gals...
Scepticism is a good thing but you can take it too far.....
Why can't you consider the possibility that this is a REAL fuzzy, wobbly, unidentified blob.... ?
... Not an imagined fictional fuzzy, wobbly, unidentified blob.
 :-DD
Post by: xrunner on April 18, 2021, 12:36:13 pm
Until, say, the last 100 years or so there would have been no reason for aliens to "alert" over this rock. Why would they come here? Since radio was invented it makes the rock a beacon of sorts, but EM waves travel at the speed they do so it takes time. Everyone (on this forum) knows that.
What gets me is the "Ancient Astronauts" shows that presume the ancient people were too dumb to build the things that they did without aliens helping them. Why would aliens have ever noticed the planet in the first place?
Post by: BrianHG on April 18, 2021, 01:02:13 pm
 :palm:
https://www.youtube.com/watch?v=mfhAC2YiYHs (https://www.youtube.com/watch?v=mfhAC2YiYHs)
https://www.youtube.com/watch?v=3viYcYPRdu4 (https://www.youtube.com/watch?v=3viYcYPRdu4)
Post by: GlennSprigg on April 18, 2021, 01:38:16 pm
What gets me is the "Ancient Astronauts" shows that presume the ancient people were to dumb to build the things that they did without aliens helping them. Why would aliens have ever noticed the planet in the first place?
It would be funny, if it wasn't so sad also, to realize that one of, if not 'the' first real TV video transmissions globally, was of Adolf Hitler at the
opening ceremony of their Olympics, in 1936 !!!  So this is the 1st video 'transmission' that Aliens would have ever seen about us!!!!   :palm:
Post by: MikeK on April 18, 2021, 07:26:01 pm
And as mentioned in Carl Sagan's "Contact" they would not have any understanding of its meaning.
Post by: electr_peter on April 18, 2021, 08:01:00 pm
In addition what is said above, I think that U[unidentified] in UFO may be taken too seriously/too formal. That is, flying object is identified, if aircraft type details, number, flight path, owner, etc. are known. If some of these data points are missing, then it is unidentified. Which obviously leads to non-trivial amount of UFO events from normal aircraft traffic. For example, in some of sightings videos exhaust of jet engines seems to be pictured from very far away, making identification not possible, thus UFO.
Post by: Bud on April 18, 2021, 09:15:20 pm
What was in it that deserved a facepalm?
Secondly, why was the TV transmission if there was no TV receivers. Who the transmission was for?
Post by: cdev on April 19, 2021, 12:46:23 am
More than a decade ago I set up an online MySQL database of farly credible UFO sightings for a space-oriented group, there were a great many simple reports on what people had seen and reported and this database concentrated particularly on the physical traces they left.
There was a curious consistency to these reports which were from all around the world.
This database was nicknamed the traces database. It may be online somewhere.
Post by: CatalinaWOW on April 19, 2021, 04:16:23 am
I spent much of my career working on these types of systems and agree that the systems are designed to minimize ghosts and other spurious images, and that those who work with them have a lot of experience in what is out there.
But the same lengthy exposure to these images and films convinced me that the world is too varied and strange to completely eliminate anything.  If you want a perfect image of a tyrannosaur dancing with a lion it will show up somewhere or sometime.  Very rarely but it will turn up someday.  Between the enormous variety of natural backgrounds, clouds, atmospheric absorbtion, rainfall, fires, geothermal sources, drones, birds, rc airplanes, and other stuff outside the optical systems and dust, scratches, over active filter algorithms and a myriad of other things inside the optical system there is plenty of raw material to generate many, many weird images.
So the key word in these UFOs is Unidentified.  They could be aliens.  But the odds are probably higher that they are some other thing which will seem totally mundane once identified and explained.
Post by: james_s on April 19, 2021, 05:08:05 am
There were TV receivers prior to WWII, electronic TV receivers were formally introduced in 1939.
http://www.earlytelevision.org/prewar.html (http://www.earlytelevision.org/prewar.html)
They did not achieve widespread adoption until the 1950s but they existed and there were broadcasts.
Post by: GlennSprigg on April 19, 2021, 05:14:28 am
The 'facepalm' was in ref to having a NAZI highlighting the 1st transmission, although of course 'Aliens' would have no understanding.
Have a look at...
https://www.guinnessworldrecords.com/world-records/first-televised-olympics (https://www.guinnessworldrecords.com/world-records/first-televised-olympics)
and...
https://www.wbur.org/onlyagame/2016/02/20/jesse-owens-olympics-germans-nazi-radio (https://www.wbur.org/onlyagame/2016/02/20/jesse-owens-olympics-germans-nazi-radio)
Not really the largest of signals! but non-the-less out there!  8)
Post by: ivaylo on April 19, 2021, 05:44:43 am
Here is the one with the triangle shapes debunked:
https://youtu.be/-r2oaQWmqkk
Post by: coppercone2 on April 19, 2021, 06:34:35 am
so the navy has cheap triangle iris on high end fighters and has no idea what they do despite 50 years of night vision technology?
That must literary occur on every single night flight ever for 50 years.
I was intensely familiar with the lens effect on a videcon tube after about 5 minutes of night time operation.
Post by: Ed.Kloonk on April 19, 2021, 06:45:58 am
[attachimg=1]
Post by: duckduck on April 19, 2021, 07:33:33 am
Two things always pop into my head when UFOs start trending on YouTube. Thing #1: Exceptional claims require exceptional proof. Thing #2: Seems like now is as good a time as ever to start filming the next installment in the Aliens movie franchise. How about "The Aliens Come To Earth"? That would be a good one. They tried that with "V" in the 80's, but the special effects were weak. Seems like modern CGI is up to the task. Aliens in business suits. I like it! Let's get a producer and a writer.
Post by: coppercone2 on April 19, 2021, 07:42:50 am
I just wanna know how people flying 10-100 million dollar planes with their entire career based on operating the thing do not know how to use the targeting cameras on the plane and what they do, that is the targeting system, that is textbook, a MIG fighter can look like that. like the enemy air force can turn the lights on and cause the strike team to play scooby doo? the plane radar and sensors don't pick up flight beacons and all other things that are emanating from civilian aircraft (the theory is that)?
Post by: Refrigerator on April 19, 2021, 10:28:38 am
Don't look too close, unless you want to see anal probing in progress.
Post by: xrunner on April 19, 2021, 11:36:30 am
I'll risk it for science.  :box:
Post by: mikerj on April 19, 2021, 12:23:04 pm
It's either a Pentagon double bluff, or the aliens are forcing them to tell lies to reduce their credibility.  It literally can't be anything else!  |O
Post by: cdev on April 19, 2021, 05:39:31 pm
I liked "Taken" the TV miniseries by Steven Spielberg.You can see the whole thing on Youtube. I wish they would finish the great story.
In the story, a girl is born of a union of the two species (played by Dakota Fanning) She ends up going on a journey to this other species home world..(what the title "Taken" is about. But that happens near the end of the series and its not included in the episodes.
But thats a story line which would really be interesting ground to cover in a TV miniseries. So they need a sequel.
Post by: Ducttape on April 19, 2021, 07:20:09 pm
Maybe the government thought they could plant a seed that might tend to reduce the political polarization that's been occurring for quite some time, and only getting worse. There's probably even an old Twilight Zone that covers this, but essentially if there is another even more extreme 'Them' (extraterrestrials) to fear it might bring everyone a little closer together.
Post by: tpowell1830 on April 19, 2021, 09:11:23 pm
Show me the little green men... furthermore, get off of my lawn!  :-DD
Post by: ejeffrey on April 19, 2021, 11:19:26 pm
What most people don't both with, even engineers who should no better, are the SNR and aperture requirements to pick up any of earth's transmissions outside of the solar system.
tl;dr: It is basically impossible to pick up earth based radio broadcasts from even the edges of our own solar system.  If we want to put up a road flare for aliens we need to pick a candidate solar system and point a powerful CW transmitter like the former Arecibo main dish (pours one out) directly at it.
Post by: coppercone2 on April 19, 2021, 11:47:16 pm
you never know what kind of receivers they have, look at the advances of rydberg technology (currently equal to decent equipment) and things like maser based receivers. I am sure that's not the end of it, there are probobly lots of undiscovered exotic RF detectors and amplifiers that might have spectacular SNR.
Post by: David Hess on April 19, 2021, 11:48:53 pm
It seems so.  I did not know that photographers had a specific term, bokeh, for it.  Or I forgot.
After 50 years the navy knows that this shortcoming is irrelevant because overload destroys the performance of the night vision equipment whether the obstruction is circular or not.  They apparently need to update their training or take it more seriously.
The obstruction might even be considered an advantage since it reveals that the focus is off.
Post by: coppercone2 on April 19, 2021, 11:49:48 pm
man if they can't use the targeting system on the plane properly (its like a rifle scope or maybe binoculars, I am not sure exactly how that plane works) those tax dollars are being pissed away, what are they shortening pilot school to 2 weeks after bootcamp because of budget cuts?
before they start hanging LED strips on loitering missiles so the airforce sends planes to 'investigate triangular UFO"
those triangles might have something to do with lens momentum and rapid autofocus, maybe thats why it its a triangle.
And the fact that this got through the pentagon is ridiclous. they need to send those paper pushers out on the air field to service planes for a while lol (I restored a severely screwed up 'oxidizing' pair of binoculars internal parts and it was NOT fun). put a damn oak desk out there and have em strip, clean and lubricate mechanical things in targeting pods that got back from the desert.
Post by: David Hess on April 19, 2021, 11:56:21 pm
It did not get by me.  I had it right when I first saw it.  They should hire me.
Post by: coppercone2 on April 20, 2021, 12:05:32 am
Do you know if special conditions make this happen? How does it not happen every single time you are approaching to land or see something at the wrong distance in the air before the camera focuses?
Is it not always displaying triangles?
Post by: fourfathom on April 20, 2021, 12:33:58 am
If you want aperture, consider gravitational lensing -- using a star's gravity to focus the signal from a long way off onto a receiving (or transmitting) antenna located on the focal line.  I used to hang out with Frank Drake, and that was his dream receiving system.
For what it's worth, I do *not* believe that aliens are buzzing the earth in their UFOs.  They're out there, just not *here*.
Post by: David Hess on April 20, 2021, 06:07:03 pm
It doesn't display the aperture when properly focused.  It should also not happen when the aperture is small enough to increase the depth of field to cover the source.  When I used my infrared monocular with the daytime cover which is just a pinhole lens, then the focus does nothing.
Post by: coppercone2 on April 20, 2021, 06:53:00 pm
I figured a plane will routinely come across unfocused things in day to day operations.
Post by: TimFox on April 20, 2021, 07:27:00 pm
In photography circles, the effect of the aperture shape (and lens aberrations) on out-of-focal-plane objects is called "bokeh", and aficionados discuss good and bad bokeh from different lenses from an aesthetic perspective.
Post by: coppercone2 on April 20, 2021, 09:29:24 pm
ok, but they are flying fast, changing altitude alot, doing spins, flying at night, landing on ships, etc. you would figure during all those flight hours seeing something out of focus would be regular. if you take pictures how long does it take to go out of focus? you run into it really quickly.
with all those pilots and all those things you would figure it would be in a power point under 'weird stuff not to get confused by' slide. or the 'things you might not know about your plane because their a little different then what you are used to with normal equipment'. I figured this would show up on a manual slide project sometime around 1960 in vietnam and be standard since then, since they had the crappiest night vision with tons of problems back then and were always doing stuff at night.
'your target might look like a triangle because....'
'sometimes you see a triangle on your screen and this can mean you should..."
'we had an incident where a pilot showed up to locartion xyz during a night time support operation and did not destroy the target because he was confused by its triangular appearance, this is normal because... and can be resolved by...'
i mean it seems pretty fucking important to know when you should change the focus..........
Post by: ivaylo on April 21, 2021, 04:49:09 am
The professionals are doing their jobs, know their tools and the tools limitations, etc. It looks like people “who want to believe“ when they lay their hands on footage like that doing creative editing, leaking to gullible journalists and such (watch thunderf00t’s analysis on youtube above). Then the Pentagon being the huge bureaucracy that it is keeps these “reports” for ever and ever... Still curious to see their upcoming report and all.
Post by: Cyberdragon on May 20, 2021, 06:11:20 pm
Fran is a believer.
https://m.youtube.com/watch?v=a6tDHZj5q5Q
Post by: ataradov on May 20, 2021, 06:20:01 pm
I do agree that we need to research this more. But the research starts not with pixel peeping on a blurry 360p video, but with equipping those planes that see UFOs all the time with decent modern cameras.
How come we can get 8K footage from Mars, and can't place a stupid GoPro on a fighter jet.
If things are as common as they are described, it should not be a big problem to film them with decent quality.
And also, you see reports from commercial pilots that they see them too, yet there are no reports from the passengers. Sure, pilots look outside all the time, but there are way more passengers, so presumably there would be massive reports and videos of UFOs.
Post by: Cyberdragon on May 20, 2021, 06:45:33 pm
Good luck finding everyone who's ever been on a plane that may have had a UFO encounter and was sitting on the right side and looking out the window and wasn't napping or listening to music and caring only about their vacation and the latest pop culture. Even if they did see something nowadays they'd be like, "ooh look, weird light...ah, it's gone now. I wonder what the latest Justin Bieber song is?"
Post by: penfold on May 20, 2021, 07:05:19 pm
Maybe this is somewhat akin to the way humans use laser pointers to confuse cats and dogs and watch them run around in a demented fashion. The aliens are probably sat back somewhere saying "aww, bless 'em, little humans, they can't even take a focused picture of us, cure world hunger or solve gender inequality and they dream of living on Mars, how cute".
Also, this jumped to mind: https://www.youtube.com/watch?v=5muY64Oyp10 (https://www.youtube.com/watch?v=5muY64Oyp10)
Post by: ataradov on May 20, 2021, 07:52:55 pm
You don't need to find everyone. And yes, people sleep and listen to music. But there bound to be some evidence if UFOs so abundant as those recent documentaries seems to portray.
"Researching" pixels on a low res video is a waste no matter what. It is one step away from looking for Yeti on trail cameras.
Post by: coppercone2 on May 20, 2021, 09:06:16 pm
I think its some kind of ball lightning plasma phase thing. there is alot of weird stuff floating around the atmosphere, maybe it makes a strange particle, condensate, phase of some kind when struck by lighting that is metastable.we make weird stuff in the lab with weird conditions. i still can't explain the weird spherical spark thing that came out of the power strip when the MOV blew in that thread, but it was not grey, but the way it navigated out of the power strip without scorching everything made it seem like it has some kind of natural tendency for 'terrain following' with repulsive forces. or maybe its something weird that comes out from underseas vents from magma.
Perhaps it has something to do with nuclear testing (why this is a more recent phenomena), having to do with the decay chains of nuclear dust in the air made by testing making specific isotopes prone to catalyzing/stabilizing/forming these spheres. Also might have to do with changing the atmospheric composition with CO2 and greenhouse gas emissions, this must have a effect on refraction, ionization, etc. Just global temperature change alone maybe has some kind of spawning pool of these things form some where in the air because of stratification of different kinds, and it might be related to solar flares and particle fluxes. There is plenty of explanations other then 'we have become a sufficiently advanced civilization to attract contact'. I think its some kind of bizzaro waste product from industrial or military activity. HAARP? We also did some strange stuff like spread dust for rain formation (silver is highly conductive and normally not scattered in the atmosphere). But I believe that
1) nature can form round plasma objects, having seen one
2) billions of reactions that can be catalyzed by really weird man made shit
3) can be some kind of weird particle analogous to a WIMP (hypothetical weakly interacting massive particle), it has visual presence but very little mass and friction (super conductor version of friction). Maybe its a single atom hit by a weird particle like a strangelet (who knows what they can do) that changes nuclear force to make it act differently but still be cohesive and some how turn visible.
I think if we captured one it might have interesting results in physics.
I would suggest two aircraft fly between it and then shoot a laser through it into a receiver to measure its transmission. they should be drones because if its doing something weird with nuclear forces and light maybe it can jump between photons to induce a voltage or something strange like that. it should be treated with caution.
Also things like superconductors are being produced fairly widely right now (even if specialized and in small amounts), since this is handled often at a university level you might assume the containment is poor and some stuff does get into the air and maybe have some kind of strange interaction with lightning.
Post by: ataradov on May 20, 2021, 09:41:47 pm
Organizing two aircraft is definitely impossible at this point if we can't have even one of them film it well.
Post by: StillTrying on May 20, 2021, 09:55:31 pm
They only appear for people who believe 8), I've seen three. :o
There are some photos and videos taken by passengers on aircraft, some of them look a lot more like a craft than a blob. :scared:
Whatever they are, around 5,000 recorded sightings are confirmed by radar.
Post by: BrianHG on May 23, 2021, 11:54:32 pm
 :palm:
https://www.youtube.com/watch?v=VCH7BWGpl5s (https://www.youtube.com/watch?v=VCH7BWGpl5s)
Post by: MathWizard on May 26, 2021, 07:52:21 pm
This is mostly a recruitment drive....and some people want to write books. And of course most UFO's are birds, drones, etc.
Just like ghosts, still nobody can get a good pic
Post by: Brumby on May 27, 2021, 02:48:26 am
Maybe the military are looking at new ways to acquire funding....?  Make a plan, get a few pilots on board, set up some scenarios and run some out-of-focus video then turn to congress for a modest budget in a two-step process.  (As well as getting some money up front, it is important to groom your audience so they are in a more receptive frame of mind for really "big" news.)  Use that funding for the construction of a Cecil B. DeMille epic to score the big bucks.  Maybe this could end up seeing the Strategic Defense Initiative revitalised and the Star Wars weapons realised - so that we can defend ourselves from "alien attack".
Here's a question:  What is the distribution of these Unidentified Aerial Phenomena around the world?
Post by: AlbertL on June 08, 2021, 04:21:56 pm
There are too many pieces that just don't add up.  If military aviators are seeing these objects routinely in a well-defined geographic area (with restricted flight access), wouldn't someone have eventually escalated the issue as a safety or national-security concern?  At that point, there are a lot of resources that could have been brought to bear on the investigation - specialized military equipment and personnel, civilian agencies like NASA and NOAA that have planes and ships with all kinds of cameras and sensors, FAA radar, spy satellites, etc.
We should be seeing a lot more than blobs on low-res IR video.  How about time-synchronized observations from multiple platforms and sensors?
Supposedly these objects have approached Navy planes at such close range that pilots have gotten photos showing surface texture.  Where are those pics?
Post by: Bud on June 08, 2021, 04:40:36 pm
It is easy to say "bring people and specialized equipment". People do not work for free, equipment cost money. It has to be a project with a justification, budget, planning, all at minimum 1 year in advance. What are your chances to instantiate such project? Projects have Requirements , Objectives, Business Case, yada yada yada. And what chances are that the phenomenon is going to be still observed when the project starts a year from now. Who wants to be accountable for the deliverables and what the deliverables are in the first place?
It is need to be understood how big organizations work. Building a solar roadway would be more attractive to one than trying to find a black cat in the dark room.
Post by: xrunner on June 08, 2021, 05:08:32 pm
And that really leads to an interesting question in my mind. What would be the type of picture that would lead to a determination of it being an extraterrestrial craft? Can any picture (or video) convince any rational person of that? Or would it require the actual craft being in a hanger?  :-//
Post by: AlbertL on June 08, 2021, 05:33:00 pm
At this point, given the poor quality of the images we've seen so far, I'd be thrilled just to see a photo which shows that the UAPs are physical, artificial objects, regardless of their possible origin.
Post by: AlbertL on June 08, 2021, 06:15:39 pm
On the other hand, the military and intelligence services - as well as some civilian agencies - are supposed to be ready to respond quickly to possible national-security threats and other emergencies.  They should have resources ready to deploy.  And since the UAPs are seen frequently, there's a good chance of catching them - it's not like they'd be mobilizing a team for a one-time event.
