Been getting a barrage (again) with solar power sellers. Latest one is warning of the danger of employing a company with little or low time spent in the business. The leaflet shows a picture of a shonky installation, a row of several solar panels, one of which is charred.
My question is how is this happening? What is the installer doing wrong that causes a panel to burn up?
Sydney. Aust.
In a nutshell, it’s that a) very high voltages are involved (600-1500V DC at up to 20A), b) cheap connectors have much higher contact resistance, and c) bad connectors, junction boxes, cable, and the like can allow water intrusion, or may fail due to weathering. So it’s critical that all the components be of top quality, and that they be installed correctly. High contact resistance, be it due to poorly made contacts, or due to corrosion from poor weatherproofing, results in overheating.
Remember also that because it’s DC, any arcs can be sustained. (It’s not like AC, where much arcing self-extinguishes twice per cycle, when it passes the 0V point.) This in turn informs connector and switch design, and the cheap chinesium clones often get it wrong.
