What is being described as a electronic circuit and what I see how it's working totally messes with my mind in a horrible way. I cannot make heads or tails of any of it. This is not how I visualize electrons moving in a circuit.
I think this is a problem. Electronics is not about electrons moving in a circuit. If you are trying to think about circuits this way, you are not (IMHO) using the right thought process.
I am a chemical engineer, so let me use an analogy. Much of chemical engineering is about liquids and gases flowing though pipes. If I tried to think about these liquids and gases as a bunch of molecules moving around, I would have quite the wrong mental model and it would be hard to understand or describe how things work.
To be sure, the molecules are there, but they are hardly ever important as such. What we think about instead is "stuff" with properties we can measure like temperature, pressure and flow (think voltage and current).
Is it just me or is the visual hardware devices in this video totally the incorrect way to see how these simple circuits operate? It's like everything is backwards or the opposite of how things supposed to be.
I think I've seen this before, but I found watching the video highly illuminating, like having a lightbulb going off in my head as I see each component. It all made perfect sense.
Am I crazy? Watching this makes me feel stupid about electronics, yet, I've been doing analog electronics for over 20 years now.
Not crazy, but lacking the right level of abstract thought in your mind about how things work. If you can reach a point where you can look at these mechanical devices, and see how they are exactly like resistors, capacitors, inductors, batteries, voltages, currents, Kirchhoff current nodes and so on, you will have a much deeper understanding of electronics.
