Author Topic: Nice Chips  (Read 2193 times)
Offline DubbieTopic starter
Nice Chips
« on: October 19, 2020, 08:13:28 pm »
There is a subreddit called "Nice Chips" where people post ICs they have used that they think are nice for some reason.
I find it interesting to keep up with what is out there. However there isn't a lot of traffic there. I thought it would be good if this forum had a thread where people can post about a chip they particularly like. Maybe explain why it solves a problem that other alternatives don't.
The following users thanked this post: sab, I wanted a rude username
Re: Nice Chips
« Reply #1 on: October 19, 2020, 08:18:04 pm »
I'll start with the Texas Instruments TPS62743
This is a buck converter that is extremely small.
On one of my boards, my entire power supply including passives only takes 5mm x 2.5mm of space. It has plenty of power for a micro and a couple of other chips at 400mA and only 320nA quiescent current.
I have been using it to power 2V micros from tiny 3.7V rechargeable Lipos.
https://www.ti.com/lit/ds/symlink/tps62743.pdf
« Last Edit: October 19, 2020, 08:21:08 pm by Dubbie »
The following users thanked this post: sab, cgroen
Offline Sal Ammoniac
Re: Nice Chips
« Reply #2 on: October 19, 2020, 09:19:56 pm »
Ummm... Nice chips.
"That's not even wrong" -- Wolfgang Pauli
The following users thanked this post: tooki, ANTALIFE, newbrain, TomS_, bsfeechannel
Offline tooki
Re: Nice Chips
« Reply #3 on: October 19, 2020, 09:44:35 pm »
Ummm... Nice chips.
And I just ate the last of these very nice chips:
1093064-0
Offline ANTALIFE
  • ( ͡° ͜ʖ ͡°)
    • Muh Blog
Re: Nice Chips
« Reply #4 on: October 19, 2020, 11:01:25 pm »
I am really digging these beetroot chips
Also for those curious this is the subreddit OP was referring to
https://www.reddit.com/r/nicechips/
Offline Red Squirrel
Re: Nice Chips
« Reply #5 on: October 19, 2020, 11:41:38 pm »
Nothing too special but given I'm a noob with not too much experience, here's one I played with recently:
https://www.onsemi.com/pub/Collateral/SG3525A-D.PDF
It's a push-pull controller that is a through hole dip package which makes it easy for breadboarding with.  I'm sure there are others but this is one I found.    Yeah you can do the same with an MCU but I always like to see if I can find a dedicated chip especially if what I'm making does not require a MCU.   This one also acts as a mosfet driver so probably better than a MCU if you want to drive really big mosfets with it.
When I feel brave enough I want to experiment using this with mains so I can make my own step down converter to drive those panel meter type bench supplies Dave did a video on a while back, I bought 3 and never actually put them to use. Could use a plug pack, but what's the fun in that?  :P
The following users thanked this post: Dubbie
Offline Circlotron
Re: Nice Chips
« Reply #6 on: October 20, 2020, 12:40:10 am »
I've used lots and lots of those and I like them too. One nasty little thing that caused me trouble for quite a few years - I made these boost converters for automotive use, 10-14V in and 16V out at 10 amps and had a pair of toroid inductors taking turns being switched by two mosfets. When I cranked up the load current one toroid would run fairly warm and the other much cooler. The pulse width coming out of the two '3525 outputs were not equal. If I manually wound the set voltage up and down there was a point where the error amplifier output would take a little jump. After much stuffing around I found that you cannot use a timing capacitor discharge resistor of zero ohms even though the datasheet says you can! Well, you can't use it without problems. Ended up using 390 ohms because I was only switching at 20kHz so that was enough. After that they ran beautifully. I was using ST brand chips. Not sure if it is a problem with other manufacturers.
Offline Alex Eisenhut
  • Place text here.
Re: Nice Chips
« Reply #7 on: October 20, 2020, 12:45:32 am »
http://www.potatosemi.com/
Never used any but funny name.
Offline Ed.Kloonk
  • Cat video aficionado
Re: Nice Chips
« Reply #8 on: October 20, 2020, 03:22:57 am »
Ah.. chippies!
To answer the OP in all honesty, there are two, the mos 6510, nudged out by the intel Pentium
iratus parum formica
Re: Nice Chips
« Reply #9 on: October 20, 2020, 03:52:33 am »
Really regretting the thread name now.
Too many absolutely hilarious comedians in here.
The following users thanked this post: Ed.Kloonk
Offline Ed.Kloonk
Re: Nice Chips
« Reply #10 on: October 20, 2020, 03:55:32 am »
I think I speak for everyone in the world at the moment, we are just blowing off a little steam.
Offline Microdoser
Re: Nice Chips
« Reply #11 on: October 22, 2020, 01:35:34 pm »
One of my favourite chips recently is the TCA9803DGKR. It's an I2C redriver that has very good voltage specs allowing an interface between devices that might not put out the low voltages required for the signal to be understood. Only about £0.70 too
Just a standard 8 pin SOIC so not imageworthy but a nice chip nonetheless
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Nice Chips
« Reply #12 on: October 22, 2020, 03:04:00 pm »
Some regulators/controllers, delivered via meme: https://imgur.com/gallery/M1S0DbI
Speaking of memes, a recommendation in this form:
No: 6N136
Yes: SFH6345
The SFH6345 has over 10x higher dV/dt rating, making it suitable for MOSFET/IGBT gate drives, and anything else.  The 6N136 is barely enough for isolating serial ports.
Or 6N137 for logic level output, or usually any of the digital isolator parts are quite good.
Dozens of other things I could think of, probably better to leave them specific to application rather than trying to list everything at once.
Seven Transistor Labs, LLC
The following users thanked this post: Ysjoelfir
