Author Topic: Nikon battery mating contacts - anyone know what they are?  (Read 802 times)
Offline VK3DRBTopic starter
« on: November 15, 2021, 03:36:36 am »
Hi.
I am designing a battery powered product that will use an external charger and Li-Ion or Li-Po batteries (preferably about 7V, 2Ah). Low volume, so I am considering piggybacking off the Nikon camera battery which ticks all the boxes.
I have having a real difficult time finding the mating PCB mount contact block for a standard 7V Nikon battery EN-EL15.
There are five contacts, each 2mm apart. The mating contacts look like blade types as shown in one of the images.
I know manufacturers in China use these blade type connectors in their aftermarket Nikon battery chargers. But I cannot find any info on the connector.
Does any body know where I can source where I can source these blade type connectors (in the charger, not in the battery) and what the part number is?
Any help greatly appreciated.
cheers,
Dave
Offline amyk
Re: Nikon battery mating contacts - anyone know what they are?
« Reply #1 on: November 15, 2021, 04:57:17 am »
Looks like they are just called "blade type battery connector". There's 2mm and 2.5mm pitches.
https://www.alibaba.com/product-detail/MISTA-5Pin-pitch-2-0mm-Laptop_62024908878.html
The following users thanked this post: VK3DRB
« Reply #2 on: November 15, 2021, 05:27:48 am »
Wow thanks! That is a start. I will contact them about a 5-pin version of "SMT battery connector", although a pin-through hole version is not out of the question. Maybe get a drawing and get some samples in. This battery connector does not have locating protrusions at each end.
If it goes well, I owe you a beer.
