Author Topic: Noise Filtering in Medical Machines  (Read 642 times)
Offline tlhsglmTopic starter
« on: April 10, 2021, 07:12:38 pm »
Hi fellows,
Noise is unwanted for measurement machines most of the time.And most of the time we are doing filtering process to a acceptible range that generally smooths our graphic. But in medical machines i think that range is very very tiny and cant let noise to achive a test results or a robotic arm's motor that works in someones brain. It's really a serius job, you cant just let noise to act a motor when a robotic arm inside of a human.
So how they are filtering the noise? I googled but there is no topic about it, maybe my key point was incorrect. Do you know how they do it or can you give me traces?
Offline MuhScopeBroke
Re: Noise Filtering in Medical Machines
« Reply #1 on: April 14, 2021, 01:52:19 pm »
There are dozens of ways to filter noise, each for different environments/types of noise. For medical devices its all about mitigating internal noise as much as possible and designing a circuit that can filter out or recognize external noise.
Offline tggzzz
« Reply #2 on: April 14, 2021, 04:40:41 pm »
Old aphorism: the soultion to all signal processing problems is to integrate for longer.
Given white noise, the best results are achieved by a "matched filter", i.e. one that is tuned to the specific signal of interest.
https://en.wikipedia.org/wiki/Matched_filter
If, on the other hand you are thinking of preventing noise being mixed with the signal, then that requires a totally different set of techniques.
