Its no longer sold by Radio Shack but its a Sanwa branded pocket DMM sold in Asia. FWIW, the DC volts is pretty accurate, after calibration it tracks to 50 DCV its spot on; but many cheapo DMMs are as so, so many Chinese cheapos can do decent work if you stay away from its weakness,which should be known; ohms is OK, ACV useless above 600 Hz, and very susceptible to non-sine wave errors.
I use it on field trips and boats with 100% humidity and often over 120F ambient, often its in a dry bag, dropped many times mostly on dirt, grass and concrete, so it has proven it can take some abuse and survive. Because the DMM is small, it has less mass, so the drops are inherently less likely to shatter something; I don't think it was ever tested to be 'rugged'. The molded rubber case does help quite a bit in repelling spray, water, coke and wine
Inside its all SMT, tight and good construction. It has a insulated foil shield a top the circuitry. It has Radio Shack on the PCB, the only movable item in it is single variable pot. I still use it with its original watch batteries, now near 8 years old. There are no soldering touch ups, cut traces and the like.
Its an example of the internal guts looking as good as the external casing, so there was some care in it overall make. In contrast, see the Uni-T model thread, which makes you think what else can they overlook.
https://www.eevblog.com/forum/index.php?topic=533.msg7664;topicseen#quickreplyI've had this Radio Shack DMM for a while, its 'rugged' and pocket-able for field use in a very abusive environment: water filled cave sites.
I just recalibrated it against my Fluke 87, as I noticed it was fairly off by a consistent amount for any range. Better now, but testing all ranges to near extremes its no where close to the Fluke. Its great for trending and especially in DCV, but not for accuracy against a standard.
I just gave away one of those meters last week, it'd been kicking around the house for at least a decade.
When i was checking it before giving it a way i was surprised to find it has a fast, latching, continuity test.
