What? Deflection is not affected by spot (beam) intensity. Thankfully. Imagine how messed up trace intensify highlighting modes would be if that were the case.
Edit to add: Oh wait, by 'spot intensity' you meant EHT voltage (higher EHT allows maintaining spot intensity despite faster sweep speeds.) Not variations in beam intensity during operation.
Yes, not in an operating sense, but as a design tradeoff. You can make wide deflection, dim CRTs, or narrow deflection, bright CRTs, but doing both is harder. (Doing both, and with high efficiency in terms of light per beam power, even more so!)
Also "anode is at the same potential as the deflection plates"... What? Is that a typo, or did you mean it?
"Simple CRT case", like a 5AQP1 or whatever -- a CRT simpler than the ones we're talking about here.
Sorry for the lacking clarity
But this is all kind of irrelevant. Point is, does grumpydoc's CRT have that kind of internal resistive EHT field shaping? (Which is primarily to achieve higher deflection gain, regardless of fine details of which way the beam curves.)
And if his CRT does have that, is the resistor open circuit?
Yeah, definitely, there'll be something funny with the deflection sensitivity, and probably linearity too, if some of that trace burns off.
Got a megger handy? Or.. maybe a picoammeter?
Not sure offhand what resistance those things are, but I'm guessing it's more than most DMMs read.
Also, if there were a broken spot, would that break down, even in vacuum? Would it have burned away enough that there's a gap or burn, visible by inspection perhaps? (I don't know exactly how much clearance is needed in vacuum, but I would think it must be at least sparking if it's dropping a large fraction of the HT across a << 1mm gap in the stuff. ...Would the sparking be detectable, say by a sensitive amplifier or radio?)
