I have a Uni-T UT33D multimeter, a "free gift" with an order from an instrument distributor. It shows odd behaviour on the AC voltage ranges, and I just wondered if I should be looking for a fault, or whether it is just as likely to be a design error. I realise it is not an enormously valuable item, and I don't want to waste time looking at it if there is nothing to repair.
What happens is on the AC volts range a small positive voltage gives a reading of about 1.8 times it's value. A negative voltage gives no reading. AC voltages around 50Hz are correct in the absence of DC.
Does this sound like a fault?
