have you cnc'd yours yet? what software do you use?
-sj
I cnc'd it about 7 years ago, but it's kind of an odd duck.
I'm VERY fond of buying surplus industrial equipment for my projects. For the mill I bought several Compumotor (Parker) servo drivers with their associated cables and servo/stepper motors. The controllers use a 'directed command language' (as opposed to simple step pulses), and they all hang on a common RS-232 line. So instead of sending step pulses out a parallel port, you actually have to send something like "A2S4M+32475G" (Axis 2, speed=4, move 32,475 steps positive, GO!). Actually, you send one string per axis, and they all start their moves when you issue the "G".
For CAD I use Corell Draw (vector). I installed a driver for an old PH Plotter (again, vector move commands) and have the system save the HPGL code to a file when I print the Corell drawing. Finally, I have a Perl package I wrote that translates the HPGL file to Compumotor command strings on the fly.
The only shortfall with my arrangement is there is no real control of the Z axis. HPGL only supports "PEN UP" and "PEN DOWN", and my Perl drives the Z all the way up, or down to a preset depth appropriately. Since I built the thing to produce 2U and 3U 19" rack panels the Z axis was never a problem. Plus I always figured I could hack the code some more to do a variable Z if I needed it.
It works pretty well, and I rather doubt that anyone has anything like it.
If it's not raining tomorrow I'll go snap a picture of the rig.
