I took the brightest light I had, granted an LED grow light, put it in a box with a slit 1mm wide cut in it. Curtains closed and we could barely make out the rainbow at 6 inches from the prism on a sheet of card.
Obviously I need a focused flat beam of light or something.
Can any of you, of wide engineering fields, suggest something that could be DIY'd and not cost $100s of dollars?
BTW, I figured a prism was the "purist" way to do this, but I'm open to other suggestions.
As a Plan Z it's a strip of addressable LEDs across the skirten board shining up the wall.
